Question about Pioneer CDJ-2000 Professional CD / MP3 Turntable with Software
Pioneer cdj 2000 loses power
When I turn on my pioneer cdj 2000 it comes on and loads as normal then about 5 seconds after it shuts down as if the plug is pulled out or if it is switched off. can anyone help ? nav2u@hotmail.com
snakehead
  • 1074 Answers
SOURCE: Pioneer SD-P55A5 Shuts off and must be reset with Main Power Switch
if you are not a tech take your set to be repaired your tv illness is in the power supply or related circuit.good luck.
Posted on May 14, 2007
  • 8 Answers
SOURCE: GPS PIONEER AVIC-S1 UPDATE
Please check the update procedure as below. It's very easy.
http://www.pioneerelectronics.com/PUSA/Support/Navigation/AVIC-S1+Firmware+Update
Posted on Jun 20, 2008
SOURCE: CDJ Laser Alignment/Calibration
They dont normally go out of focus, any trouble reading discs / freezing is usually caused by a worn out laser which will require replacement.
Posted on Sep 24, 2008
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
SOURCE: Shuts down after 30 seconds
Maybe the audio amplifier IC are burned
Posted on Jun 29, 2009
Kerig K40 leaking coffee out the front of it
my pioneer cdj 850 power is not coming up after losing and cleaning it i mistake-ling interchange the cover and the boot player refuse to come up
Jan 19, 2017 | Coffee Makers & Espresso Machines
Hi, have a problem with my one of my pioneer cdj 800 players: every time I switch them on, they don't launch simultaneously; while one is working properly, the other one needs up to five minutes to...
my problem is that my cdj 2000 loses power when I switch it on
it comes on and after like 5 seconds , it just shuts off and wont come on when I switch it back on
email me with any suggestions, nav2u@hotmail.com
Jun 13, 2013 | Pioneer CDJ-800 Turntable
My touch release is turned to the fastest setting yet when I release the cd to start it drags for the first second then plays normal
I believe you are trying to play a record rather than a CD. It is slipping on the mat when you start playing. Your other CDJ hasa better "grip"
Sep 30, 2012 | Pioneer CDJ-800 Turntable
My pioneer cdj-1000 mk2 is turning off when im in a club.....I really need help.. it just shuts off and after 25 minutes it works again.....i think its the power supply
open up the unit and check the biggest capacitor on the psu board. see if there is any movement in it. it should only have a little movement left and right if you have up and down movement its probably come away from the board.
May 27, 2011 | Pioneer CDJ-1000MKII CD Player
When switching on the unit and loading a cd it can take a long while to register the cd then it will play for a few seconds then stop. this will clear after a few minutes and play as normal, however if i...
No this is not a common issue. If your traverse assembly is not damaged, then it's possible the loading motor might be the issue.
In either case, I would suggest professional assistance.
Hope this helps.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 18, 2009 | Pioneer CDJ-800MK2 Turntable
Pioneer cdj 800 display often goes out, but comes back on after I give it a good whack (yeah I know, but it worked in Back to the Future and for my cdj's). What's the problem here/where can I parts
I am an aircraft mechanic not an electrician, but I narrowed it down to the power supply. Somewhere on the power supply there is a connection that is making a bad connection. I will keep looking and post if found! :)
Jun 28, 2009 | Pioneer CDJ-800 Turntable
I have a problem with my cdj mk2 800
I could not understand what you just wrote.
Yes, a video would be best.
Although it sounds like the loading motor might be faulty.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer Parts
DJ Parts
Pioneer DJ Equipment Sales
Audio Video Accessories
Mar 27, 2009 | Pioneer CDJ-800MK2 Turntable
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Pioneer CDJ-2000 Professional CD / MP3 Turntable with Software Logo
21 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
