Question about Refrigerators
SERVICE MANUAL GSL25XGWC
Lights come on inside the fridge No lights on the control panel by ice dispencer Fridge wont come on too cool down freezer wont come on also
SOURCE: Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Posted on Dec 10, 2007
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
tech master
  • 120 Answers
SOURCE: kenmore fridge model#596.52679200 side by side
remove back cover on evaporator inside frezeer if is full of ice all over then you have a defrost problem and you might have a faulty defrost timer or defrost thermostat repl both so you wont go wrong if the coils are clean and not frost is on coils then check compressor to see if its running just by touching you can find out if it si not running then you have a faulty relay or overload repl and compressor should start.if there is only partial frost then you have a leak or restriction depending when you bought it most refrigerators have a maufactures warranty on compressor for about 5 years call for service on the number on the sticker inside refirgerator
Posted on Oct 14, 2008
Krames
  • 18 Answers
SOURCE: My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Posted on Nov 15, 2008
SOURCE: lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Posted on Sep 24, 2009
Control panel off lights in fridge and freezer on but not working
Unfortunately the control panel is probably defective. But check for power to the panel. This controls the temp of the freezer, fridge and the solenoid control valves for the water and ice maker. What is the Year, Model and Make of the refrigerator?
Mar 22, 2015 | Refrigerators
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Kenmore 795 freezer on top. Freezer working, temp lights on in fridge, but fridge not cooling and lamp out as well.
If the freezer is located above the fridge, the air from the freezer drops into the fridge to create the cooling in the fridge. So what I would look for is a blocked vent from the freezer to the fridge, which is usually located on the top and or back of the fridge inside of cores. You can get a frost or ice build up in there and block the air flow to the fridge, that is usuall the problem. I would also heck the dial for temp control in the fridge, I know my kids have changed it before on me.
Sep 07, 2012 | Kenmore Refrigerators
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
My fridge wont get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
My control panel on the freezer door stopped working all together. Everything else on the fridge is working fine just the panel for the ice and water dispencer and all the lights on the panel. Thanks Eric
Make sure the wires on the left top door hinge are still connected. They are usually under a plastic hinge cover.
Sometimes there are wires on the bottom left door hinge that get disconnected when you move the fridge as well.
Mar 11, 2010 | Refrigerators
FP E381T, lights won't stop flashing, fridge not cooling properly
There is another fan to draw air into fridge compartment- access via fridge: remove back panel (long plastic cover- just clips off). Remove control housing (again, just clips off- careful of wiring though). Fan is located up in this channel between fridge and freezer compartments. However, from what you are describing, I think you have a blockage in the freezer drain, causing a build up of ice in the freezer which blocks the air flow to fridge.  To check, remove rear panel of freezer (clips off- you need to press down two clips at top of panel, they can be tricky to get off!!). Disconnect fan motor wiring by unclipping plug connection, and remove sensor wire(white wire) so panel can be removed completely. Now have a look in the trough underneath the evaporator, and check for ice buil up- there should be no ice in this trough. If it is iced up, you need to defrost ice and then pour some water in the trough and see if it runs away. In the middle of the trough there is a small hole where the water should run down and away to collector tray at rear of fridge- if this hole is blocked, water won't run away, so builds up and freezes and blocks air flow to fridge. If hole is blocked, poke a wire down to unblock.
If in doubt, call in the experts- F+P fridges can be a bit fiddly getting apart, as everything clips together ( I worked for F+P for 10 years, and I still sometimes have problems getting panels off easily!!)
Good Luck!!
Mar 10, 2010 | Fisher Refrigerators
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
