Question about Refrigerators
Search Fixya...model MFI2665XEM6 - icemaker not working
The icemaker is not working
Kenmore elite would not dump ice then will not fill
model number and type would help. top freezer? side by side? etc. If refrigerator otherwise working good, buy the icemaker KIT from homedepot.com or lowes. should include solenoids, and complete icemaker. type in appliance repair in the home depot search engine. should not be much over $125.
Feb 01, 2014 | Kenmore Refrigerators
Water dripping from icemaker and freezing in freezer
Hi and welcome to FixYa, I am Kelly.
If the ice maker is over-filling check the rubber tube that comes through from the back of the refrigerator. If you notice that the tube also has ice in it.... The inlet water valve is bypassing water when it is supposed to be closed. The only remedy for this is to change the inlet water valve. If the ice maker mold body has corroded and is leaking the icemaker will have to be replaced. 95% of the time when an ice maker leaks and causes sheets of ice in the freezer the inlet water valve has failed.
Parts sources:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
Once you do a MODEL search on any of the above sites your parts diagrams will appear.
If someone in your household has even limited mechanical abilities they should be able to change this inlet water valve. Just make sure the unit is powered off before doing the change.
Thanks for choosing FixYa,
Kelly
Jun 21, 2011 | Refrigerators
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
Ice maker stop working
Hi and welcome to FixYa. I am Kelly.
What is the exact model number of your Refrigerator? I need to know if it is the optical sensor type icemaker or the simplified one.
This manual ( <- click and download) should help you troubleshoot your icemaker.
I am going to post this as a solution but... if you need more information, just repaond here and we will gladly help you again. Just note that we will need a complete model number when you respond.
Thanks for using FixYa.
Kelly
May 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Will the refrigerator work if the ice machine is not hooked up?
You need to have the icemaker assembly in the unit. Now unless you are talking a clrco2075 you have to hookup the water. If its a regular icemaker then by lifting the arm everything should work. The icemaker has sensors in it and thats why you need the icemaker in place. What model do you have? Just to be sure, some models you have to program the icemaker to stay off.
Jul 16, 2009 | U-Line Refrigerator Ice Maker
Bin Arm
It probably broken, these do not normally just come out. Please go to www.u-lineservice.com and click on the parts distributor search engine. These parts are available and this icemaker can be repaired. It's a little tricky to replace, but it can be done. Make sure to cut the power when working inside this icemaker.
Aug 31, 2008 | U-Line Icemaker
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
