Question about Electronics - Others
Maxell dsr 1
What are the specifications on the ac adapter details of voltage rating and Milli amp ratings
    Problem Solver:
  • 9 Answers
Mujy ap ki bat samj nai aa rahe
Posted on Jul 15, 2013
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
Mar 04, 2011 | Maxell Flat Speakers With Subwoofer and...
Can using the wrong Toshiba ac adapter destroy or damage your Toshiba computer?
Take a look at the sticker on the bottom of the laptop, and also on the AC adapter you have. IF both ratings for Voltage AND Amperage match exactly (as in, say 18V, 3.8mA), AND if the connector fits snugly (no 'wiggle room' means no constant shorting, which can destroy a motherboard, believe me), then I'd try it myself, in a pinch anyway. I've found laptop adapters on a particular eBay vendor named sib-usa to be perfect matches, as long as you search their 'store' for your exact model (again, on the bottom sticker on your lappie)--and they're pretty cheap, many if not most going for under $15, including the shipping! I've bought dozens from them for my own local PC repair clients--even my own brother. Hope this helps.
Feb 18, 2011 | Toshiba Computers & Internet
I have a maxtor 120GB external hard drive but no power supply. How do I get a replacement? I tried a switchable power adapter from a local hardware shop and although I set the voltage to 12v it lights up...
Hi Dave.
The problem you are having is the adaptor you tried is the right voltage but not the correct ampage. You require a 12v dc adapter with a rating of at least 1-Amp. The switchable supply you purchased would be well under the required level, probably 400ma (milli-amp), in other words about half the needed amount. A cable modem power adapter would be sufficiant. If you have one, make sure it is the correct voltage and polarity, positive pole (+) usually the inner pin on the end of the connector. Hope this is of some help to you.
Jan 25, 2011 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
My baterry won't charge... Connected to AC adapter.. WIndows 7 shows plugged in and cheging but battery charge won't go up. I have replaced battery and AC adapter both but still same issue.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 24, 2010 | Toshiba Satellite M115-S3144 Notebook
Gateway lt21 netbook not charging
Sep 13, 2010 | Gateway Computers & Internet
Need ac power adapter for 9v for portable dvd player
I have a lot of power supplies.
is it a positive or negitive tip 9v power supply and what is the milli amp rating?
May 19, 2010 | TruTech PVS12701 Portable DVD Player
I need to know what the amperage rating is for the USB ports on the Dell Inspiron E1505 laptop. It does not appear to be defined in the owner's manual.
most USB is 500 milli amps (which is 1/2 amp) @ 5 volts,
Some hubs can only provide 100 milli amps - but this usually when you have a dongle that give you more USB ports and it doesn't plug into some power source (to provide the extra power).
Feb 27, 2010 | Dell Computers & Internet
GP4101 Powere Supplay
The Ultra AC Adapter has the following output specification.
Rated Output Voltage - 9 Volts DC at 200 Milliamps to 1.3 Amp Max
Center of pin Positive
Pin Size
Length - 9.5 mm
Width - 5.5 mm
Center Hole - 2.1 mm
Sep 03, 2008 | Gyration Ultra Cordless Optical Mouse
HP Pavilion ZD7360 US generic adapter problems
As long as the power rating of the power adapter is the same )voltage and amp rating), you will be ok,
Dan
Apr 08, 2008 | Computers & Internet
Electronics - Others Logo
44 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
