Question about Vehicle Parts & Accessories
Lights keep flashing, alarm going off, and car will not open with the remote
  • 109 Answers
Start the car to reset it
Posted on Jul 15, 2013
  • monica delatorre Jul 15, 2013
    The car does not start since the alarm is going off..
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
I have a clarion rk20 keyless entry and remote start on my 2003 jeep grand cherokee it works fine but whenever i remote start it, its parking lights continue to flash as if the hazard lights were on?
After doing some poking around, I found that flashing parking lights are an indication that the remote start is being used. According to the information I found, the parking lights shouldn't keep on flashing after your 2003 Grand Cherokee has started. I am assuming that your parking lights, however, continue to flash even after the engine has started and you have put your Jeep into gear. Please let me know if that is the case as if it is then you likely have a short somewhere in the wiring that is telling your alarm system's brain that the remote circuit is still being used.
In order for something like this to happen, the major power line is usually pulled high when the remote is activated. When it is pulled high, the computer tells your car's parking lights to enter flash mode. What should happen next is that when the system has fired, the line should drop back to standard voltage and, at that point, the change in voltage should tell your parking lights to go back into standard mode.
What is happening instead is that the flasher light activation circuit remains high even after it is supposed to reset to normal.
The usual cause of this is a short somewhere on the input side of the alarm circuity. It is this side of the circuitry that pulls the parking lights into flash mode. It may be as simple as a short in the alarm system's switching wire harness (even something as simple as a loose crimp on a spade connector or a molex plug insert can cause it.
If you do not have easy access to the switch wiring, the wiring harness or loom, I would suggest taking it to a good alarm shop, telling them what is going on and having them trace the circuits until they find the troublemaker.
Nov 05, 2014 | Cars & Trucks
2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
I disconnected the battery when I reconnected the battery the alarm keeps going off
If a aftermarket alarm then disconnect it ,these auto remote start alarm things are useless and all go wrong with age
Oct 20, 2012 | 2005 Dodge Caravan
Power lock remote control is not working to open and close the doors while burglar alarm light (armed) keeps on flashing. When any door is opened, sound keeps "on" to indicate problem. The...
Check under the hood. Often, there is a small switch that needs to be closed when the hood is shut. This switch sometimes comes loose and when the hood is closed the button is never pushed. Find the magic button and reattach it to it's mount so that the hood will press it when the hood is closed and that should solve the problem. This button works with the alarm system.
May 25, 2011 | 2001 Honda Accord
No dash lights or odometer reading when you open the door and car cranks but will not start. Alarm is in vallet position. Few weeks ago paaenger window would not work then started working then driver side...
I would start by removing the pesky alarm. My encounter with alarms is they create more problems than they actually help a badly wired alarms systeme can be a true nightmare. My advice the best lock for your vehicle is the lock that locks the gas and brake pedal together best invention yet good luck
Sep 24, 2009 | 2002 Dodge Caravan
Car alarm goes off
is the battery the right one for the remote ie; size/voltage. check for lights inside (map,reading,etc) left on causing the bat to discharge.
Nov 23, 2008 | 2001 Mazda MPV
1999 JEEP GRAND CHEROKEE LAREDO
i have a 95 jeep grand cherokee lerado from time to time my alarm goes off i dont have a remote 4 my alarm but i found out that if you put the key in the driver door and unlock it. it will reset the alarm!!!!!
Nov 19, 2008 | 1995 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
20 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
