Question about RCA Audio Players & Recorders
Mp3 player headphone jack
Headphone audio goes in and out when plugged in on the mp3 player but not on my laptop... help!!!
5 Suggested Answers
SOURCE: Problem with the headphone jack
On some creative mp3 players like my 20g sleek photo, the problem stems from poor design on the solder joint inside the unit. I did a search and found a tutorial with pics on how to take it apart and resolder it. It works now but cosmetically it's not 100%. If it's still under warranty, I think for $20 bucks you can send it back and they'll fix it....goodluck!
Posted on Jan 02, 2007
  • 3 Answers
SOURCE: Headphone Jack
the plastic pieces on the top and bottom are just stick on. pry them off gently and you'll find four of the tiniest screws on the top and bottom(you'll need a precision screwdriver) after you remove the screw pull the metal pieces on top and bottom off carefully with the screwdriver. the whole piece is shoehorned in, but it will push out just far enough to reveal the aux. jack. you'll probably find that this piece is cracked and that is why it only play through one or no sides. i'm still looking to find this piece.
hope this is helpful to you,.
Posted on Jan 04, 2008
djcrowe
  • 17 Answers
SOURCE: Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Posted on Sep 09, 2009
  • 68 Answers
SOURCE: headphone jack
You must have not plugged in it properly, force the jack till the end of the socket so it locks in with a click, then it will work fine.
Posted on Jun 07, 2010
Cable Connect iPod iPhone MP3 Phone Audio to Mazda Car Player
Does your car player have a auxillary jack (looks like headphone hole)
or does it just have a tape player?
if it has an auxilary plug then you need to plug the cable from your ipod into that and set the stereo to aux for source.
if the car has a tape player go to the store and ask for the cassette that plugs into your headphone jack. then you can put that tape into the tapeplayer and plug the other end in your headphone port on the ipod and listen away
Oct 04, 2012 | Elandpower Aux 3.5mm Cable Connect Ipod...
How to play ipod on koss progressive scan
Take a look at the inputs on the DVD player. If it has an AUX input (looks like a headphone jack) you may be able to connect with a male to male 3.5mm headphone jack. Otherwise you could use a converter that goes from headphone jack to RCA (Red, White, Yellow)
Jul 30, 2012 | Koss KD305A DVD/CD/MP3 Player Progressive...
Headphone jack
Jun 07, 2010 | Audio Players & Recorders
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Headphone connection
Common to all mp3 players - there are a few videos on YouTube purporting to show you how to fix the headphone jacks, but they usually don't work. Replace the mp3 player is the only solution.
Aug 22, 2008 | SanDisk Sansa m240 MP3 Player
Sound Problem with Headphone
First try the headphones in a different machine, such as an mp3 player or cd player to make sure the headphones still work.
Try going to the start button, then settings and control panel. Then select "Sounds and Audio devices" Down at the bottom you should see "Speaker settings." Click the "Advanced" button and then select stereo headphones.
Then, place the headphones into the green audio jack (or the headphone jack up front if you have them), play some music, and then gently wiggle the jack to see if some of the sound makes it into the headphones. If not, try slowly pulling the headphones out of the jack while the music is plaaying. you might find that the jack has slipped a little and may play only if your connector is slightly pulled out or more firmly pushed in. If his helps, then your audio connector is loose and you should replce the sound card. If the card is on the motherboard, you can disabled it when you put a new card in.
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone issue on Zen Micro.
you have a loose connection on your headphone jack, need to solder the jack back in place.
Dec 07, 2007 | Creative Labs Zen Micro MP3 Player
Button/Jack
Replace the player - there is no repair for this
Jul 02, 2007 | iLO (2 GB) MP3 Player
My headphone jack may be messed up
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Mar 28, 2007 | SanDisk Sansa c140 MP3 Player
11 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
