Question about Vehicle Parts & Accessories
2002 dodge durango
Trying to figure out what this part is thought it was the purge valve but its not were getting codes for evap. Have replaced hoses & gas cap. Vehicle surges from time to time but if that part is taken off & blown out it will stop for a few days. Any ideas?
    Top Expert:
  • 5,332 Answers
That is the leak detection pump. The purge valve is under the hood. It will have two smaller vacuum lines going to it.
Posted on Jul 14, 2013
  • esther coronado Jul 14, 2013
    The part is located on the driver side underneath kinda by driver door
  • Jeremy W.
    Jeremy W. Jul 14, 2013
    Yup, near the charcoal canister. It is the leak detection pump.
Where is the evap on a 2005 dodge durango
The purge valve is up on the engine. the vent valve is by the gas tank or at the charcoal filter, the lines run from the tank and filter to the engine. the lines are plastic, except under the body, metal then. Codes would be nice. This would tell me where to look.
Nov 13, 2014 | 2005 Dodge Durango
Emissions Code
Error Code: P0441
Fault Location:
Evaporative Emission (EVAP) System - Incorrect Flow Detected
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
- Purge control VSV connector disconnected.
- Evaporative Emission (EVAP) Canister Purge Regulator Valve is faulty/jammed.
- Evaporative Emission (EVAP) Canister Purge Solenoid Valve faulty/jammed.
- Evaporative Emission (EVAP) Canister Sealing faulty.
- Pipes between Tank Breathing and Throttle Body leaky/blocked.
- Hose connection(s).
- Intake leak.
Solutions:
- Check Evaporative Emission (EVAP) Canister Purge Regulator Valve.
- Perform Output Test.
- Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve.
- Check Evaporative Emission (EVAP) Canister.
- Perform Basic Setting.
- Check Pipes between Tank Breathing and Throttle Body.
Jan 10, 2014 | Toyota Cars & Trucks
Codes0441 0442 0455 0456
codes po441 po442 po455 po456. code po441 - EVAP system no flow during purge conditions.code po442 -EVAP system small leak detected conditions. code po455 - EVAP system large leak detected conditions.code po456 - EVAP system very small leak detected. possible causes loose damaged missing fuel cap.fuel tank sensor disconnected or failed. ORING on top fuel sending unit leaking.purge valve vapor line clogged disconnected or purge solenoid failed.vent solenoid not closing or has failed.
May 23, 2013 | 2002 Dodge Durango
What is code p455 on the check engine light?
p455-EVAP Contol System Leak Detected Gas Cap EVAP canister purge valve stuck closed Loose hoses
Nov 29, 2010 | 2001 Dodge Durango
I have a obd code of PO456 for a 2003 dodge Durango.Do you know what that would be.
When you get the code,find out what it is,or buy a code reader and a book of codes
PO456 EVAP Contol System Leak (Very Small) 0.508mm (0.020 inch)
Gas Cap
Holes or cuts in fuel vapor hoses
Loose hoses
Evap Component failures
Vent solenoid open
Canister Purge Valve,issues
And on and on
Have a smoke machine put on the system and repaired
Nov 05, 2010 | Dodge Durango Cars & Trucks
2003 DODGE DURANGO CODE P0456
Usually this P0456 code is caused by an incorrect or faulty gas cap. Filling the fuel tank with the engine running could conceivable cause this code as well or if the cap wasn't properly tightened. Any of the following could also be the cause:
  • A small leak in any of the EVAP hoses or fuel tank hoses
  • A small leak in the purge valve or vent valve
  • The EVAP Canister may be leaking
Aug 14, 2010 | 2003 Dodge Durango
Im getting a P0441 EVAP emission control system purge flow fault code on my 2002 dodge neon
Here is what I could find for your code error as potential causes:
After market parts and accessories nonconforming to the EVAP system specifications.
Damaged, missing or improperly installed fuel filler cap.
Blockage in fuel vapor hoses/tubes (EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube) in EVAP system.
Disconnected or cracked fuel vapor hoses/tubes in EVAP system.
EVAP canister purge valve stuck closed.
Canister vent (CV) solenoid stuck open.
Fuel tank pressure (FTP) sensor malfunction.
EVAP canister leaking.
Fuel vapor control valve tube assembly blocked.
Fuel vapor vent valve assembly blocked.
Obviously the gas cap would be the easiest and cheapest thing to fix.  Just make sure it is put on correctly and tight.  If it is not that, I would have to suggest to take it to a mechanic because the other problems on that list are not really DIY material.  Hopefully it is the gas cap and you can take care of it yourself.  Good luck.
May 17, 2009 | 2002 Dodge Neon
I have fault code P0441 showing up on my 2003 Dodge Durango. Not sure what this code is, or how to correct it..
P0441--
Evaporative Emission Control System Incorrect Purge Flow.
This indicates that a part of the EVAP control system is no longer functioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
EVAP emission canister purge is controlled by a valve which allows engine vacuum to pull stored fuel vapors from fuel tank into the engine to be burned, rather than be vented to atmosphere. A vacuum switch is used to detect when flow exists. If the PCM commands purge and sees that the switch is closed (indicating no detected purge flow) P0441 is set.
A code P0441 could mean one or more of the following has happened:
* Bad vacuum switch
* Broken or damaged EVAP line or canister
* Open in PCM purge command circuit
* Open or short in Voltage feed circuit to Purge Solenoid
* Faulty purge solenoid
* Restriction in EVAP solenoid, line or canister
* Corrosion or resistance in purge connector
* Bad PCM
Here are a few solutions that should be followed to fix this issue.
* Common Chrysler fix - Replace Leak Detection Pump / LDP
* Repair damaged EVAP lines or canister
* Repair open or short in voltage feed circuit to Purge Solenoid
* Repair open in PCM purge command circuit
* Replace purge Solenoid
* Replace vacuum switch
* Repair restriction in Evap line or canister or solenoid
* Repair resistance in purge connector
* Replace PCM
Please rate and god bless:)
Apr 14, 2009 | 2001 Dodge Durango
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
