Question about Lands Phones
I purchased the uniden DECT 1515+1. Went to make a call in another room of house and phone displays "searching" Returned phone to base and after 1 week it still says searching. Both phones now will not ring or let me dial out
SOURCE: Phone says "Searching" and will not work.
como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
goalie39
  • 469 Answers
SOURCE: After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
Posted on May 05, 2009
supernova278
  • 1932 Answers
SOURCE: searching and out of range message keep appearing.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Posted on Jul 27, 2010
michelletrip
SOURCE: I have a Uniden DECT 1480-5c phone (base 5
have this EXACT same problem---could it be my wireless router interfering??
Posted on Sep 26, 2010
My base unit unit keeps flashing 8-88, and the hand sets all say searching
If there is an error code with an E followed by a number or "88" displays/flashes it would be an internal issue in the base unit. Uniden does offer a limited 1 year warranty (Covers Manufacture Defects ONLY, if caused by a power surge or power outage or any other type of damage that is not a Manufacture Defect this is not covered under warranty) off the proof of purchase. The proof of purchase is required for warranty service.
May 10, 2015 | Uniden D1484-4 Dect Cordless Phone With...
Uniden 6.0 dect phone interchangeable with different 6.0 uniden
when the battery cover comes off there are a series of microswitches that are visible.. make sure the new ones are set with your originals..
Jan 11, 2014 | Uniden DECT 6.0 Cordless Telephone...
Uniden Dect 6.0 d1384-2 display says searching
I have the uniden 3005 accessory handset that pairs with the uniden 3015. I tried all the above holding down of buttons etc. none of that worked. I finally rang uniden and the technician said to put the accessory phone on the base unit where it's connected to the phone line. This worked and the phone registered, then I returned it to its own base that it came with. Uniden need to amend their manual wording so that it reflects the above steps.
May 02, 2012 | Uniden DECT 6.0 Cordless Phone ID
I just received your Dect 6.0 from E.Bay....second-hand....I need to download the manual for it in order to use it properly.....Thanks...MC...!!!!
Which model of the Uniden DECT 6.0 phone do you have? They make several. All of the Uniden manuals are available from Uniden support and on the individual product page. If you start at http://www.uniden.com, you can search for your model.
DECT phone manuals are listed here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Then scroll through the list to your specific phone and desired language for the manual. The model number is on the base of Uniden multi-handset cordless phones. The number after the dash indicates the number of handsets that come with the base when purchased new but the manuals are identical.
To access all Uniden manuals, start at http://www.uniden.com/scat/cordlessphones_mnl and select the type of device.
If you add the model number in a comment and I'll be glad to provide a direct link to the manual that you need. For example the Uniden DECT1060 manual is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1060om.pdf .
I hope this helps.
Aug 01, 2011 | Uniden DECT 6.0 Cordless Phone
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
My phones went dead and went into searching mode. Phone lines are working just not base
Your base station is dead, this is common with Uniden phones. You will need to purchase a new base station. You can use the new base station with existing phones as long as you buy a compatible model.
May 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
Often one of the three phones will display searching and I cannot use any of my phones in the house.
Try to take out the batteries of all the phones. Unplug the phone base for 1 minute. Plug all the batteries back in to the phones. plug the power back in to the phone base. That should reset your phone set up thus eliminating the problem.
Mar 13, 2010 | Uniden DECT 6.0 Cordless Telephone...
My uniden dect 6.0 model# 2088 base doesn't display anything and the handset says out of range
disconnect the battry and the phone like from the base and the phone(s) and them put them back together and see if it works.
Mar 12, 2010 | Uniden DECT-2088-2 1.9 GHz Twin 1-Line...
Question:
Answer:
May 05, 2009 | Lands Phones
Uniden DECT 6.0 - 2 Handset
You may have to manually "register" your handsets to the base. This is supposed to do it automatically but there are instructions for "registering" your handsets if the automatic feature fails or you add a new base, etc. Consult your owner manual for instructions.
Nov 29, 2008 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
70 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
