Question about Dometic RM2620 Refrigerator
Ignitor will not stop clicking
My fridge is lit and running fine, but the ignitor is continually trying to lightthe flame that is lit.
    Top Expert:
  • Dometic Master
  • 4,292 Answers
Bad control board not showing rectification
Posted on May 27, 2016
2 Suggested Answers
  • 122 Answers
SOURCE: Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
Posted on Jun 07, 2009
BROILER HAS NO REGULAR IGNITION DESPITE THE FACT THAT THE VALVE AND IGNITER ARE FINE AND BROILER AND ORIFICE IS IS CLEAN. GAS PRESSURE AND FLOW IS FINE. ONCE LIT (MANUALLY WITH A LIGHTER) THE FLAME W
How do you know the ignitor is fine? The ignitor for the oven is different than that of the burners. Rather than clicking, the oven ignitor will glow red. If when you turn of the oven you don't see a source of red light coming from under the oven bottom your ignitor is bed.
Aug 30, 2014 | Kitchen Ranges
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
I have a freezer that does not work it clicks on for a few sec then cuts off what could be wrong
The clicking is the electronic ignitor trying to light the gas.
Either it's not getting any gas to light , or the flame sensor is not telling the computer that there is flame , so it shuts down the gas.
Most fridges have a small shut off right at the gas valve in the back of the fridge , it might be turned off. Put your ear up to the back cover of the fridge , if you hear it sparking and then you hear flame but it goes out after a few seconds , than it is the flame sensor. If you never hear the flame blowing , than it is not getting gas. Could be several different reasons. If you have disconected your tanks , maybe the gas has just not made it to the fridge yet. Newer ignitors try 3 times and then shut down if no flame is detected. Old ones only try once.
Apr 27, 2010 | Thetford Norcold RV Cooler/Freezer
Won't srtart
Check at the gas valve to see if you are getting power to the terminals after you hear the click shortly before the ignitor stops. If no voltage ...replace the board.
Sequence is
induction fan on, if pressure switch is reading ok condition---->
Ignitor is powered for up to 20 seconds (depends on model) ----->
Gas valve is energized ----> if flame is present everything just works away, if no flame in 3 seconds sequence starts over for set number of tries or continuously (again depending on the model)
Hope this helps
if 23/27 volts is present at gas valve then replace valve but bad valve is not very common usually, its the board.
Nov 08, 2008 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Apr 14, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Ignitors continue to fire even after the burner is lit
The switch sounds like it is bad. It has ; off, lowest setting going up to highest, then light, that's what makes the spark or clicking, right. Is this the top burners and do they all do this? If the ignite module runs too long it could over heat and burn out. But if they are all doing this you have a problem with it or the relay anyway.
Dec 26, 2007 | DCS 24-24G-1 Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Dometic RM2620 Refrigerator Logo
51 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
