Cat problems with WIN8
No communication with PC running WSIN 8 and USB to 232 converter.
    Top Expert:
  • 12,223 Answers
Use the utility system restore go to control panel, and put the last date that you know was working good.
God bless you
Posted on Jul 15, 2013
Where can I locate and download a windows PC driver for NS-PU99501
The Insignia NS-PU99501 USB to serial (RS-232) converter cable should be a plug and play item with Windows 7 and 8. This assumes an active internet connection and Windows Update is set to search for drivers for new devices. See https://www.insigniaproducts.com/pdp/NS-PU99501/5883029 and go to the Support & Downloads tab to find the manual and the driver for a Macintosh OS.
The Prolific chipset in this Insignia device is the PL2303. For other Windows versions, try http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41 for the driver.
I hope this helps. You may need to check the chipset suffix with the tool on the above Prolific support site.
May 15, 2018 | Computers & Internet
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
Sound is not working for Dany u1050 usb tv device in using win8
Download and install a Windows 8 compatible driver from the URL below.
www.dodownload.net/drivers/dany-u-1000-1050-2000-usb-tv-drivers.html
Jan 25, 2014 | Computers & Internet
Asus laptop x43u just installed windows 8..now cannot access boot selection
Win8 starts so fast-F" or DEL is now disabled often.
Download RESTART TO EUFI from http://www.asrock.com/mb/AMD/FM2A75M-DGS%20R2.0/?cat=Download&os=Win8 and install it.
It does not always work with other makes of board, but worth a try - if not you HAVE to reset the BIOS to defaults
Oct 30, 2013 | Computers & Internet
Gd-0912-u usb win8
you can force windows 8 to use windows 7 drivers, you just need to force it to accept it, unzip to a folder and point to that folder.
Oct 24, 2013 | Computers & Internet
Can ADAM 4051 module can be connected to LAN Net . If so please give me the connectivity Diagram.
Seems not possible directly. ADAM-4561 is basically an USB to RS-232 converter, so you need a RS-232 ( Serial) to Ethernet converter again.
Dec 03, 2010 | Advantech ADAM-4561 (ADAM-4561-A) Serial...
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
