My aiwa pieces cuts off when volume is turn high, can someone help with the solution?
Check your speakers to see if they are match correctly and also you may have a short
Posted on Jul 17, 2013
How can I play my ipod on an Aiwa NSX-AJ310?
Simple!!! All you need is an 3.5mm to RCA cable, they're reasonably cheap.
Connect the RCA cable to the auxilliary inputs located to the back of your system.
Insert the 3.5mm jack into the headphone compartment of your ipod.
Turn on your system and then set the function to VIDEO/AUX. It'll be advisable to lower your volume, so that you may not cause any damage to your speakers!!
Play your ipod, make sure that all the volume is up.
Now, gradually turn up the volume on your AIWA system, and the music is supposed to be playing through your system. If not, refer to your manuals.
Hope this helps!!
JaHa
Nov 30, 2009 | Aiwa NSX-AJ310 Shelf System
I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Aug 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Aiwa Colour Television Model TV-SX2150 KE - Audio Problem
i can solve ur prob by your self but u have to pay for that.
Apr 01, 2009 | Aiwa F2000 20" TV
Why does the volume go all the way up when i put it to 15?
aiwa typical issue. loved my aiwa's sound hated the stereo. my volume control knob did the same thing and i had to order a new control.
please take time to rate,
good luck
Ryan
Feb 16, 2009 | Aiwa NSX-DS55 CD Shelf System
Aiwa CXZL 31 volume button seems stuck
all u have to do is turn the volume down once then bang it against the door 5 times...it should be fine...
Jan 04, 2009 | Aiwa Audio Players & Recorders
Volume high but no sound only a very low static sound
Make sure the unit is not swiched to tape monitor. Check to see if all inputs and outputs are wired properly. Unplug unit and let it sit unpowered for a half hour to reset micro-processor which may have locked up. When you power it up again, listen for click of speaker relays. Make sure to turn volume down BEFORE you power up. If none of these work, take unit to pro tech for check up. It just might be a simple fix, cheaper than replacement. Good luck.
Apr 02, 2008 | Aiwa AV-D67 Receiver
Power cuts out
This problem happend to my sony system about a year ago. It was the amp that blew in mine because of the fan inside the system was not coming on when it should of. I found that when i had put my PC in the AUX jacks it blew the fan on me, so every time the volume got to 15 the system would just shut down and not come back on at all, or it would need time to cool down before it would start up again. Take it to a shop and get it looked at by someone that knows what there doing. Please dont try and do this yourself.
Aug 14, 2006 | Aiwa NSX-AJ205 CD Shelf System
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
14 people viewed this question
 Grubhead
Grubhead
