Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Jul 14, 2013
Red screen - Hitachi 51F510 51" Rear Projection HDTV-Ready Television
bobby caesar
Level 2:
Champion:
  • Expert 247 Answers
  • Posted on Jul 18, 2013
bobby caesar
Expert
Level 2:
Champion:
Answers
247
Questions
Helped
28532
Points
498
Go to the ez adjust menu and reset the factory values do not select the ad9883 u may damage the tv u will need a tech
2answers
Bravia kdl-32l5000. Why does it have a red screen?
Color circuits are messed up and need repair.
1helpful
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Display has red tint across entire screen. Could it be the bulb? If so, is that still available? Approximate cost?
two possible solutions----either a problem on the small circuit board that is connected to the RED picture tube OR the red screen control is turned up too high. These sets have a small square block with RED,Green, Blue screen controls(same place also has red, green, blue Focus controls) if you remove the speaker grill you will find an inspection plate made of masionite---the focus/screen block is visable behind it----get a flashlight and look carefully at the block---one row of 3 plastic shafts is Focus(don't touch those) the other 3 are Screens(you should see R, G, B marked) go to a blank video input(one with nothing attached) and turn the RED SCREEN CONTROL JUST SLIGHTLY TO THE LEFT UNTIL the red goes away.
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
CRT problem
you need to adjust the red screen control of the crt under the speaker grill turn it down with the tv running.
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
2helpful
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
6helpful
2answers
Red screen
how to lower the red screen voltage?
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
