I don't know how to open the projector to change the bulb out. Please help
    Problem Solver:
  • 12 Answers
We need some more info. What is the model of the projector?
Posted on Nov 30, 2013
How do i remove the bulb from a gaf 2100r slide projector
The bulb pulls out. You don't want to twist it, because it is seated with one big pin in the middle and four smaller ones around it. The big pin in the middle has a fin on it, to make sure you get the others in their right places.
To get the old one out, you want to remove the metal housing for the lens that surrounds the bulbs. Pinch the sides that are next to the open end of the housing a little bit and jiggle it. It'll come out fairly easy. Once that is out of the way, you can get a good grip on the bulb and pull it straight out.
As for new bulbs, you can find them on the Internet. The best price I last saw was for $27.
Dec 30, 2012 | Office Equipment & Supplies
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
My sony vpl-es2 displays the image with a green tinge to it. My settings don't seem to make any difference. The problem is difinately on the projector as I have troubleshot all other options.
Your bulb is going out. replace the bulb and you should be fine.
Just remember to set back to defualt settings before your change the bulb out and make sure your give the bulb time to pre-heat before you turn the project all the way on.
Jul 02, 2011 | Sony VPL-ES2 Multimedia Projector
BE HAVE A PT-L720U PANASONIC PROJECTOR AND HAVE NOW REPLACED THE BULB. THE RED INDICATOR LIGHT IS STILL ON AND IT WILL NOT POWER UP WHEN PUSHING THE POWER BUTTON... HELP...
Your projector key pad is locked. Know you can use remote control if you don't have then you hold down the MENU and ENTER button together 5 seconds then press Power key if problem not remove
repeat again
Jul 02, 2011 | Panasonic PT L720U Multimedia Projector
I have a BenQ PB 6210. After switching it on, it first displays that the lamp has run 2001 hours and should be replaced. After this window disappears, it takes maybe 2 seconds and the projector shuts...
Hi cholthusen,
Please be informed that the average lifespan of a projector's lamp is around 2000 hours. The light bulb is almost certainly the problem. The best solution would be to change the bulb. The easiest way to do that is to change the lamp assembly (fresh bulb is in the new assembly). You may also try resetting the unit. Turn the unit off, then physically remove the power cord. wait for about 10-15 seconds then start it back again. If this did not work, please replace the lamp.
Hope it helps.
Thank you for using FixYa.
Jun 23, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
There is no light coming out of the projector, I have replaced the bulb and still no luck
Welcome to Fixya!
Have you placed the bulb right , i mean if you shake it really hard you may damage it , moreover check the position of the bulb if it stays fitted ,
More over Your lamp has a warranty typically. No matter what, don't expect any more than 1,000 hours out of a projector lamp, and budget accordingly. I had my first lamp go, in low power, when rated for 5,000 hours - at 1,200 hours
This is the way projectors work, and is unfortunate, but ignore the owners manual, because if the lamp was really going to last 2,000 hours they would WARRANTY it for 2,000 hours. The fact that they don't clearly show that how much it lasts for.
Now how can you prolong the lamp life.
i believe most home use projector's lamp's life can over 2K hours at lab.
but the environment should be as:
1. no use it over 3 hours each time.
2. keep the room degree at 20-25C
3. keep your room very clean.
4. adjust projector's fan speed to fast
Do comment if it helped you in any matter
Apr 19, 2011 | Televison & Video
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
How do I open the top of the projector to replace the light bulb?
Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
Feb 10, 2010 | Televison & Video
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Feb 21, 2009 | Epson (V13H010L34) Projector Lamp for...
289 people viewed this question
jasbo
jasbo
