Question about Titan Advantage 400 Airless Paint Sprayer
Small leak from gun of titan 400 advantage
While spaying, small drips come out of the guard on the gun, in between the tip and the guard. This hasn't been a huge deal other than while painting doors. The few drips it gets on the door, ruin it. Thanks for any tips
  • 4 Answers
Try reduce the pressure or change the spray tip seal areyouusingthe correct size tip for the paintyou are sprsying
Posted on Aug 17, 2013
3 Suggested Answers
SOURCE: I have a titan 400 i paint sprayer, won't prime..
sometimes the ballbearing in the shaft where you dip into the paint gets stuck .if you unscrew the end of the shaft and clean the ballbearing.then put back together and try prime again.
Posted on Apr 23, 2009
  • 885 Answers
SOURCE: Clogged Titan 400 Airless Paint Sprayer
There are two check balls in the pump that make it work. If either are blocked or stuck it will do what your are stating. Tapping the pump with a hammer will work to free check balls that are stuck to their seat by corrosion but will do nothing to remove paint chips or dried paint that prevent them from working properly. You can try forcing water throught he pump while it's running with a garden hose to see if that will clear any problems. If that doesn't do it you will have to disassemble the pump to clear anything that's keeping it from working. If you're familiar with the workings of a paint pump, it's not hard but be careful not to damage the packings, piston or cylinder.
Posted on Oct 02, 2012
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Hi my titan 400 its leaking from the oil cap area, I reduced pressure and still leaking?!
Hi Kamil,
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
Jan 13, 2015 | Titan Advantage 400 Airless Paint Sprayer...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Titan advantage sprayer stops pumping
Yes im sure you see you need to clean the mechine and all filters after each use if you ever want to work again
Apr 11, 2014 | Titan Advantage 100 Airless Paint Sprayer
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Oct 01, 2012 | Titan Advantage 400 Airless Paint Sprayer
Can i use this spay gun to spray down bed lineing or is it caapable to do it???
Not likely
The tip will be too small for
bed liner material
Check the specs on the product
you want to use
May 23, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
In use for 1 hour and did not want to continue working just stopped.
You posted under spray gun.
I don't know if you are taking about the gun stopping or the spray rig stopping
The gun stopping:
We used airless spray guns for years.
Maybe your tip is clogged.
With our guns we reversed the tip, and could shoot the clog out.
The spray rig stopping:
Add a comment with more specific information about the type equipment you are using.
What material you are spraying.
What settings you have on the rig that can be adjusted.
How old the equipment is, if it's been cleaned well in the past.
Maybe GFCI tripped if you're outdoors.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 10, 2011 | Air Tools & Compressors
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
Titan Advantage 400 Airless Paint Sprayer Logo
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
