Question about Epson Office Equipment & Supplies
Calculator printer not feeding - Epson Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Epson Master
  • 102,366 Answers
What model calculator?
Posted on Jul 14, 2013
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Mar 18, 2010 | Canon P1-DHV Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
How do i install the printer paper???
i can not feed paper into printer on my calculator
Jun 23, 2009 | Canon P1-DHV Calculator
How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
Jun 20, 2009 | Canon P1-DHV Calculator
Printer Paper
NOT A SLOT TO FEED IT SPECIFALLY
CLOSE THE COVER TILL IT FEEDS OUT
Oct 23, 2008 | Casio DR-T120 Calculator
Canon 1008 D paper won't feed
check from free of any foregin object droped inside (pins -stapler-small pieces of torn paper.-reset the calculator(off and on).apply light grease on gears and check if it is fine ok. if not pass it to service center.
Feb 20, 2008 | Canon BP120 DH Calculator
Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Feb 01, 2008 | Canon P170-DH Calculator
Printing
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
