Question about Weed Thrasher For Gas Grass Trimmer Wacker Eater
Snapper S31BC fuel line diagram for a Snapper S31BC gas powered weed wacker
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
I have a craftsman gas weekwacker model 356.791520 is there any diagram of the fuel lines. I think I repaired them wrong.
Looks like you've possibly referenced the wrong model # for your trimmer. There is a diagram available for model 358.791520, but not a 356.791520. You can find it here - http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358791520/0247/1503820?searchedModel=791520&blt=11.
Once you get the Sears numbers for parts you need, you can find replacements for them at HyperParts.com's cross-referencing page here.
May 19, 2010 | Craftsman 25cc Gas Line Trimmer
Have a snapper snap n' go trimmer s31sng - One of the fuel lines or more were cracked and It quit running - replaced all fuel lines but don't think I reconnected them correctly. Do you have a diagram of...
I am not really sure how many lines you replaced. But the fuel line layout on most types of trimmers, weed wackers and lawn mowers are pretty straight forward. There is usually a line inside the gas tank for connecting the fuel strainer\filter. Then a line from the bottom of the tank to the carburetor. This line may also have a fuel filter located on it. On more complicated equipment you may find a breather line that loops back to the carburetor.
Below are a couple of links that might be helpful. The first three are diagrams of a similar 31cc Snapper trimmer and links to other Snapper trimmers. The fourth is to the users manual for your trimmer.
Hope this helps.
http://www.partstree.com/parts/?lc=snapper&mn=311+31cc+Straight+Shaft+Trimmer+Series+1&dn=6600
http://www.partstree.com/parts/?lc=snapper&mn=310+31cc+Straight+Shaft+Trimmer+Series+0&dn=6597
http://www.partstree.com/parts/?lc=snapper&mh=19
http://dl.owneriq.net/a/a3fbde0d-dc76-4963-935f-821589699385.pdf
Sep 01, 2009 | Troy Garden
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Apr 12, 2009 | Garden
Istuctions for fuel line installation on weed wacker
The esiest way to figure it out is to take the line with the filter and put it on one nipple then push on the primer a few times and see if fuel comes out of the other, if no fuel then switch the line over to the other. But if im not mistaken the filter will go to the bottom.
Oct 20, 2008 | Homelite Consumer Products 4.0 Amp, 13 In....
Weed Thrasher For Gas Grass Trimmer Wacker Eater Logo
55 people viewed this question
Top Weed Thrasher Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Weed Thrasher Heavy Machinery Expert? Answer questions, earn points and help others
