Question about Lenovo Computers & Internet
Cursor moves erratically - Lenovo Computers & Internet
  • Lenovo Master
  • 7,627 Answers
Internal touchpad or a external mouse?
Posted on Jul 14, 2013
Testimonial: "internal. It is not a touchpad issue. Already tried that."
  • 14,384 Answers
Is your mouse for a laptop,check batteries,to stop it,just click,replaced mine recently and it is doing what yours is doing.,it's a gear head,other was a microsoft.
Testimonial: "None of those are the solutions.It is a lenovo issue not MS issue. They have had problems with this since 2008. I was just hoping there was a software fix. Apparently there is not. I have a feeling I can going to send it in and get back the same way."
  • Thomas Perkins
    Thomas Perkins Jul 14, 2013
  • max carson
    max carson Jul 15, 2013
    Remove Battery and USB adaper, leave out, 30 mins. or so, reboot laptop, insert USB adapter, reinstall battery in mouse. If it's the Touchpad, adjust the sensitivity in the Touchpad Software in Control Panel, select Mouse Icon or look in the Tray Notification Area for the Touchpad icon, maybe Synaptic software, this may help: http://www.thewindowsplanet.com/1014/con...
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Dec 29, 2013 | HP EliteBook 2730p Tablet PC
Erratic cursor ms media centre wireless keyboard
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
Dec 28, 2013 | Computers & Internet
Cursor won't move
Go to your control panel and click on mouse then click on pointer options and move that left or right and click apply. Keep doing that till you get it to how you want it.
Nov 12, 2011 | Video Game Consoles & Games
ACER ASPIRE 5517 Notebook computer. Erratic cursor
i have seen this problem in other laptops and the mousepad had to be replaced.
Apr 27, 2010 | Acer Aspire One PC Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Erratic cursor
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
Oct 22, 2008 | Toshiba Tecra M1 PC Laptops
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Erratic Cursor Behavior
Are you sure your not touching the pad as you type , a common error, cover the pad with card board or plastic and see.
otherwise you may have a bad touchpad and it needs replaced or re-seated on the cable.
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
