Question about Boating
A12v10w bulb for boats
Where can i get a replacment bulb
    Top Expert:
  • Boating Master
  • 42,092 Answers
Best place would be from a marine dealer spares as most auto bulbs are either 5 watt or 20 watt bayonet type.
Posted on Aug 07, 2013
Mercury 40 2011. Boat starts great but will turn off after 10 to 18 minutes of use. I then have to pump primer bulb a lot of times. I have replaced with new primer bulb but with continue to shut down.
Just some pondering........
Runs
good when cold but when warms up it dies.
Have you checked for spark at the plugs right after it died?
Have you tried priming it (squirt gas into carb)
What happens if you pull the choke on the moment that it starts to die?
Wild guess? Vacuum leak at carb gasket. If bolts are not snug, when the engine warms up it might expand enough to let air in past the gasket.
Please reply as a COMMENT to this post.
Jan 03, 2016 | Boating
Bosch 36 volt flashlight bulb doesnt last
Here is what I have done for now. I was able to pick up a 24 Volt 10 Watt G-4 Base bulb at a local Boat USA store. So far so good. I had it running for 6 hours straight with no issues and still working.Finding a 36 Volt bulb replacement has been difficult and the bulbs don't last.
Dec 18, 2013 | Bosch 2610948135 36 Volt Replacement...
Anchor light wireing for hurrcane deck boat
Check the electrical connections, bulb and switch.
Jun 26, 2013 | Westland Godfrey Pontoons & Deck Boats...
User manual for 55hp Suzuki
does the bulb get sucked out ?
if it does right at the tank there is a valve that have a little marble you just have topch it back or change the gas coupler that have the valve
Aug 21, 2009 | Light Outboard Motor Boat Bass Fishing...
Pumped up bulb, never does get firm, engine will run 30 seconds
You need a firm bulb. There is a checkball in the gas coupler. There should also be a float valve in the carburetor. If you have a friend with the same brand of motor (or a boat shop) it is easy to attach your tank to a different motor. If your tank will now give you a firm bulb, the floatvalve in your motor is bad.
If the bulb will not get firm with the test motor its your line. They are not expensive <$20.
Aug 12, 2009 | Boating
1994 JOHNSON 200 WONT RUN AT ALL WITHOUT CHOKE'ON CARBS CLEAN. WONT DRAW FUEL FROM CARBS COMP GOOD. EX CLEAR ,GOOD SPARK,?NEW TIMING BASE NO HELP. POWER PACK NO HELP. WONT IDLE AT ALL, RUNS FOR ABOUT 10...
If you have a primer bulb and the motor "recovers" after a near stall with a pump of the bulb, then you have to replace your fuel pump. Johnsons do have this problem often. Otherwise it could be the high speed jets although it sounds like you checked the carb good. Also if you have a primer bulb, Replace everything from the tank to the engine. Costs about $14 at Wal Mart, $55 at a boat place.
Jul 06, 2009 | Boating
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Light bulb number 1992 Tracer
The bulb number is A12V10W (12 Volts, 10 Watts). The easiest thing to do is to visit an automotive parts store as they usually have a bulb replacement manual which will list most of the bulbs based on the make, model, and year of your vehicle. The other alternative is to visit the link below and input the aforementioned data (I am not sure if the number that you will find on the website will be universal or only a Sylvania part number) http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/
Nov 23, 2008 | 1992 Mercury Tracer
Boating Logo
55 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
