Question about Yard Machines Garden
Pto cable installation
    Guru:
  • 145 Answers
? push mower? I could help with a model number
Posted on Apr 13, 2014
The pto cable on our White lawn tractor has broken 4 times in the past 2 years...help
Either a very poor quality replacement cable or there is something binding causing you to out too much stress on the cable. The pto should be relatively easy to engage if bit there us a problem with it.
Jul 27, 2016 | Garden
How do I replace the PTO Drive Cable Instructions or exploded diagam
Mower Clutch Cable Replacement - Craftsman Riding ...
? 5:37
www.youtube.com/watch?v=pSXOBQojHgg
Aug 22, 2014 - Uploaded by RepairClinic.com All of the information in this clutch cable replacement video is ....Riding Mower Electric PTO Clutch Won't Engage When Hot Problem Fix ...
Aug 05, 2015 | Garden
Pto switch will not work...it was replaced tnd it still will not work
check for voltage at pto if voltage there jump pto at the wire hub on pto if still pto dosnt come on bad new pto return it for new one and they get bad one it is a problem if good pto check voltage at pto should be 12.5 at least if not you got a bad stater 200.00 for it then install another 100.00
Aug 29, 2014 | Garden
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
PTO stay engaged on allison transmission md3060/ PTO chelsea 277
wires to the pto solenoid incorrect and not wired properly through the switch
did you put the correct shims under the flange of the pto mount as it it is incorrect distance , the pto teeth will say jammed in the transmission gear teeth
suggest that you take it to a shop that fits pto and have the installation checked before you damage the transmission
Mar 12, 2013 | Garden
Hi, I have a 2008 Kubota L3400 HST and recently developed a problem with the PTO not turning off when when the PTO lever is shifted to disengage. I have disconnected the two small wires to the PTO lever...
I just fixed the same problem. The cable running from the PTO shift goes into the transmission case under your seat. You can follow the cable down and where you see a rubberboot, spray DW40 on it liberally. Work the PTO shift back and forth and wait five minutes. Do again if necessary. The spring load under the seat seems to seize up and the cable doesn't slide properly. This is one of the reasons for this problem that is easily fixed. The other a broken snap ring internally that is a much bigger problem.
Good Luck
Apr 21, 2011 | Computers & Internet
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
PTO Issue
It sounds like you got the cable to tight. The brake cable applys the brake to the pulley to help stop the blades when PTO is disengaged. With it being tight it might be applying the brake and that is the reason your blades are not running at full speed. If you keep using it that way it will wear out your brake and possibly damage a pulley. I suggest you loosen the brake cable or replace it with a new one.
Aug 31, 2009 | Garden
Garden Logo
19 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
