Sylvannia tv caption - Televison & Video
    New Friend:
  • 109 Answers
You didn't explain anything but go to menu of tv remote go to settings and you can chance it
Posted on Jul 15, 2013
Captation on TV screen can't get it off
Hello
To choose a Captions or Text setting, press "TV/CAP/TEXT". Each press brigs up a different settings. your closed-caption?text options are:
CAPTION CH1, CAPTION CH2, TEXT CH1 and TEXT CH2.
Note: Not all programmes carry closed captions or Text. If captions are available, they will probably appear on 'CAPTION CH1'
Press "TV/CAPTION/TEXT' button on the remote control repeatedly to On and Off the caption function.
Dec 29, 2011 | Zenith TVBR1322 13 in. Combo
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
I haven't been able to put closed captioning on tv. I don't understand how and what code to use to get the closed captioning to work.
Enable Caption Using the Original Remote
  1. Press the [CCD] button to change the CCD mode.
  2. Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
  1. Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
  2. In the Setup Menu, choose the Caption option.
  3. Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
  • Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
  • Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
  • Digital Caption Style: There are two Caption Styles. One is the automatic function set as the broadcaster, while the other is the custom style where you can adjust the font size, color, opacity, background color etc., accordingly.
Mar 10, 2011 | Element ELC-HS321 32 in. LCD TV
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
Nov 15, 2010 | Toshiba 27A44 27" TV
Cannot hear the sond on Sylvannia TV 6615LCT
This will sound strange, but some DVD players and cable boxes have separate volume controls. I would check the settings for both of those to make sure that the volume has not been turned down and also check the connections from the dvd player and cable box to the tv. Make sure all connections are solid.
Apr 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Auto code search didn't work.
call sylvania or down load a free manual pdf for your model
Jun 29, 2008 | RCA RCU403 Remote Control
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
Top Televison & Video Experts
