Question about Samsung DV337 Electric Dryer
Samsung DV337/DV328 dryer will turn on, but it wont start
Last week the dryer would turn on and run for a few minutes, then it would stop for a few minutes before starting back up. The clothes were always dried on time. But now, the dryer will power up and count down but will not actually start.
SOURCE: My Samsung DV337 Dryer also runs for a short
I just encountered the identical situation, after putting a multimeter to all the sensors it turned out that the thermistor was bad. I replaced the thermistor part # DC32-00007A and it eliminated the problem. You will have to remove the top and front of the unit to reach it. It's the sensor on the right in the picture.8_20_2012_10_24_55_pm.jpg
Posted on Aug 20, 2012
SOURCE: Samsung Electric Dryer
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
Posted on Sep 26, 2008
  • 1531 Answers
SOURCE: Samsung DV337 Dryer; the motor runs but the tumbler not turning
you need to remove the top of the dryer first then remove the control panel. then all the screws from the front panel then you can look inside and see what is going on
Posted on Sep 27, 2009
  • 8 Answers
SOURCE: My samsung dryer does not stop drying even when
You need to replace the main PCB board. They have upgraded the board.
Posted on May 06, 2010
  • 20 Answers
SOURCE: dryer stops after 2 min run
change its thermistor.
Posted on May 23, 2010
Samsung front load electric dryer not getting hot
There is a thermal sensor type breaker leading to the heating element. They are usually round, about quarter size, with a spade connector on each end. They can be checked by a OHM meter to see if they make a connection from one terminal to the other. There may be more than one. If that checks good then you need to check the heating elements for resistance for one end to the other. If there is no resistance then the element is bad.
Jan 23, 2014 | Samsung Dryers
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
My Samsung DV337 Dryer also runs for a short amount of time and then stops. I'm getting a code that looks like an upside down F, followed by an o. I can't find this code in any service manual...
Aug 09, 2011 | Samsung DV337 Electric Dryer
Drum want turn, everything else shows ok
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 08, 2010 | Samsung DV337 Electric Dryer
My samsung dryer will not turn any suggestions? It is less than a year old was working fine and when I switched loads the unit lights up just will not turn
Door switch...
heatman101
Oct 24, 2010 | Samsung DV337 Electric Dryer
Samsung DV337AEW/XAA wont turn off by timer. we
The timer has gone out rplaceit and all should be fine
Oct 27, 2009 | Samsung DV337 Electric Dryer
Apr 12, 2009 | Samsung DV337 Electric Dryer
Samsung DV337 Electric Dryer Logo
104 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
