Question about Sewing Machines
Frister and rossman sewing machine model az
The centre button to select reverse will not push in to put the machine into reverse.all levers ect in the inside have been oiled and move when stitch length or needle left or right are turned on the respective turn dials
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
SOURCE: Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Posted on Jan 23, 2009
bargainbox
  • 1388 Answers
SOURCE: model 385.15718500..machine only goes in reverse
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
Posted on Aug 02, 2009
I've just been given an industrial frister Rossman but was told it needed oil before use. How do I oil it please?
What is the model? Generally, most sewing machine have oil ports. Place a couple of drops in every port and joint you see. Let the machine run until loose.
Apr 25, 2017 | Sewing Machines
How to use a Waltons Celestial 516 sewing machine?
I conducted a rather through search with Google, Bing, and Yahoo and did not find a free users manual for this machine. The links below are 1) for a contributor who possessed such a machine and 2) for a company that claims to be able to sell you a manual to a machine which your machine is "rebadged" from. That is, the machine was sold under several brand names.
FixIt contributor Andrew Rose in 2013 indicated this machine was a rebadged Frister and Rossman 64 or 66. I found only links to sites purportedly selling manuals for these models and can not easily evaluate if the sites are legitimate or scams. Andrew Rose actually indicated he had the very machine you mention as well as a manual. But Andrew only made 4 postings and may not be available to contact. http://www.fixya.com/users/arose62
That said, here is a link which offers a F and R manual for sale and shows a picture of the Frister and Rossman 64. http://sewingonline.co.uk/frister+rossmann.html
Aug 12, 2015 | Sewing Machines
Frister & rossman manual for model979
check with sewvacdoctor.com
Feb 19, 2012 | Sewing Machines
I need a manual for frister and rossman model E sewing machine is manual
sewingparts.co.uk
A very helpful link and an easy and quick download of the manual.
Highly recommended by my experience.
John H.
Nov 12, 2011 | Sewing Machines
There was not a written manual for this sewing machine White 1866 Where can I get one? You all keep posting that one is available but I can not find it
That model is exactly the same as Necchi, Kenmore twin dial, Frister Rossman, Toyota, the machine is made for several manufacturers who put there own name on it try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Aug 14, 2011 | White Sewing 1866 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
