Question about Watches
Casio watchs 2328
Second hand does not work and stopwatch work
  • Watches Master
  • 18,424 Answers
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
escapement
  • 2334 Answers
SOURCE: Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Posted on Feb 09, 2009
escapement
  • 2334 Answers
SOURCE: How do I zero-out the minute hand of the stopwatch?
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If thi do not work, do the same using the button at 4 o'clock.
Rate me, please.
Posted on Mar 26, 2009
escapement
  • 2334 Answers
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Posted on Apr 03, 2009
SOURCE: second does not reset to 12
You should be able to solve this by pulling out the Crown(the one with which you set your normal clock), Pull it out in the 2nd stand.
Then by pushing the 'start/stop' button --> you change the minutes.
By pushing the 'lap/reset' button --> you change the seconds
It worked for me, took me a few minutes to figure it out, i hope this saves others the time of doing that :p
Posted on May 26, 2009
Hamilton jazzmaster watch
The large hand is the chronograph (stopwatch) hand and only moves with the stopwatch.
Mar 07, 2012 | Hamilton Laboratories Hamilton Jazzmaster...
How do i set the time on a 5057 casio watach, when i hold down the adjust button the stopwatch second hand moves, and i cnt set the time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
May 01, 2010 | Watches
Do as follows:
Rate me, please.
Apr 03, 2009 | Watches
Rate me, please.
Mar 26, 2009 | Pulsar by Seiko watch PF3359Men's 100m...
Invicta model 3209 watch
Your watch is fitted with chronograph movement 5040D made by Ronda (Switzerland). If you take a closer look, then you will realise that the subdial at 3 o'clock is counting seconds allready. This is your seconds dial, not the big one.
The big seconds hand actually is the chronograph hand (stopwatch) and, when activated, works together with 1/10th counter.
Follow this link and see for yourself:
http://www.ronda.ch/e/index_bedienung.html
Find movement 5040D and click on INTERACTIVE version.
Rate me, please.
Mar 25, 2009 | Invicta 3209 Lupah Diver Watch
1/20 second hand on the G shock not on the 0
Not sure why but the "home position" may be out of sync. Look under "Adjusting the home positions" in the owner's manual and follow directions to correct this problem.
Feb 23, 2009 | Casio Watches
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Watches Logo
113 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
