I replaced my water filter. I drained the water dispenser for 7 minutes. I threw away the old ice. I turned the ice bin upside down and shook it and a spring fell out. Where and how do I put the spring back?
SOURCE: Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
SOURCE: Ice and water dispenser lock
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: my side by side kenmore refrigerator has stopped
plz chec ur filter & colling pipe as well as worked efect.
other than u can reset ur all macine point............
SOURCE: know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
