No sound from AV receiver, sound only from TV
SETUP: - HDMI Connection from BD player(BDPS300) into AV Receiver(BD HDMI IN) - HDMI Connection from HD PVR 2U into AV Receiver( DVD HDMI IN) - HDMI Connection from AV Receiver(OUT) into SONY HD TV (KLV40S400A)
    Genius:
  • 1,054 Answers
What brand/model is the receiver. Some have a function where you can select if the audio is passed through to the tv, or output from the receiver's speaker jacks.
Posted on Jul 15, 2013
Nova_1
  • 196 Answers
SOURCE: Connecting PVR and satellite receiver
make sure you have a connection from one of your scart sockets (assuming you are using scart) on your sat to your pvr and then a connection (scart/hdmi?) to your tv from the pvr.
if you have a second scart or better still hdmi on your sat then plug that into tv
set top box scart output to tv
you do not say which tv model number you have so I dont know what input sockets you have but I will assume a couple of scart inputs and maybe a hdmi in (if hd version of tv) these days that would be considered a minimum amout of inputs so the setup suggestion above should be fine with that
Posted on Oct 14, 2008
TWITCHDADDY
  • 54 Answers
SOURCE: connecting new Sony DVD player to a TV, VCR, & Comcast cable box
wheres the dvd hooked up
Posted on Feb 14, 2009
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
  • 53 Answers
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Posted on Dec 29, 2009
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
Posted on Jul 06, 2010
Can't get ARC to work with my samsung ue48hu7500
Have you checked the settings on the tv? You may have to enable the ARC functions in the setup menu.
Apr 13, 2015 | Marantz SR6006 Home theater receiver...
I have a VR-6025Z 60"
unplug TV and Bluray power cords from wall socket, replug HDMI cable in both units, replug power cords back in, turn them On and check.
Let me know how it worked. it seems Bluray player set its display resolution bit higher that TV doesn't support.
Please connect Bluray in TV by usual AV cable (yellow-red-white) and go to BD player setup menu and reduce HDMI Out resolution like 1080p to 1080i, then check it in TV HDMI input.
May 14, 2017 | Westinghouse LVM-42w2 Television
RX-V663 won't change input automatically
Be sure to have HDMI Controll function turned on in the Setup Menu. But also the DVR and BD player should support this.
For example I have both Toshiba DVD player and Popcron Hour player connected via HDMI to my receiver which is then connected via HDMI to TV. When I turn on DVD, it changes the input on receiver and also on TV. But the Popcorn doesn't support it won't change anything.
Mar 01, 2010 | Yamaha RX-V663 Receiver
No picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Feb 28, 2010 | Denon AVR-589 Receiver
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Televison & Video Logo
Top Televison & Video Experts
