Has been gassed. If I drive at 60+ for 10 mins the air con starts to work ???
  • 109 Answers
What are you talking about no info
Posted on Jul 15, 2013
  • gregpither Jul 15, 2013
    Vito 2007 air con not working
Why would the a/c only work in cool weather or when driving at high speeds?
possible on old school air con
air in system
needs a re gass
aircon compressor pump clutch slipping in and out
tx valve sticking
May 19, 2016 | Cars & Trucks
Cruze - hot air from driver side and cold from passenger
Do yourself a favor an take it to repair shop before you mess it up or hurt yourself !
May 14, 2015 | Cars & Trucks
Fault finding air con
double posted now. and still no country stated, (what you have varies by yours countries laws.. SMOG rules,etc)
check fuses, first
second, is the fan blowing. in heater box in dash.?
3rd is the compression main shaft spinning, not clutch the SHAFT.
Jul 01, 2014 | 2007 Jaguar X-Type 2.0
97 Mercedes 250 td. Question is the climate control is not working right. If you set to cool (air con ) and turn the fan up to full it sounds like its on, but even if you put your face to the vents it has...
Blend door issue? Is there air blowing any where else like floor or at your feet? I would start there. If you have air elsewhere, then your issue is blend door. May sure the flow of air moves as you change the setting.
Jul 02, 2017 | 1997 Mercedes-Benz C-Class
A/C re-gassed and still does not work ?
You first have to be sure that they have charged the system with the correct amount of refrigerant, not too much, not too little. -2) Refrigerant level could be just right, but if Radiator cooling fans are not working at full speed, a/c won't get cold. -3) a/c condenser [the thin radiator in front of the Radiator] has to get good air flow through it to cool the refrigerant & bring the pressure down.. check for blockage of air flow there.-4) if al else fails, have refrigerant drawn out, evacuate system to -25 psi vacuum for 45 min. then recharge system to proper level by volume in lbs. & oz's., not just psi. pressure. This will ensure correct refrigerant level for optimum refrigeration.
Aug 09, 2012 | Cars & Trucks
Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Mar 27, 2012 | 2003 Audi A6
Rplacing an AC compressor on a 2002 Volvo S70
will be ok compressor will not operate until system is gassed pulley will just freewheel . the oil will be put in when system is gassed a pressure switch in the air con pipe prevents it operating until at correct pressure
Dec 06, 2009 | 2000 Volvo S70
A/C does not blow cold air.
Hi. It will need to be re-gassed at ur local air con place but b4 u take it there make sure the compressor is working when u turn ur air con on. If the clutch on the compressor does not engage its a sure sign it is out of gas.
Aug 01, 2009 | 1999 Ford Escort
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
