Question about Kitchen Ranges
Washer will not move into rinse cycle
The machine works fine on the wash and spin cycles. However, when the beginning of the rinse cycle is reached, the timer does not advance, there is a humming sound and no water is dispensed. During the wash cycle only warm /hot water will dispense....no cold water. Everything on the washer has been checked and I don't know what is left to check. I have replaced the water valve, the cold and hot hoses and the control board. The hoses have been checked and are hooked up properly to the cold and hot valves. What is left to trouble shoot? Please help. This has been going on for 2 weeks now and I have incurred $$ to fix and nothing!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model?
Posted on Jul 14, 2013
eagle338
  • 4889 Answers
SOURCE: right oven 2 burner natural gas.burners stay on for 20 seconds.
Looks like something is blocking the burners from the insides.. My mom has fixed a similar problem of my neighbor yesterday...the solution is to disassemble the burners and clean it thoroughly and put them back on..
Good Luck!
Eagle.
Posted on Apr 12, 2008
SOURCE: Whirlpool Washing Machine that doesn't complete the cycles
I too have a whirlpool top load and it did the same thing. I would put a load in and go back and the clothes were sitting in water. I found that if you close the lid and press gently til you hear a click, it will finish the cycle. So now when I load the washer, I press the lid like that and I have not had the problem since. I hope this helps.
Posted on Jan 20, 2009
  • 289 Answers
SOURCE: Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Posted on Nov 18, 2009
  • 289 Answers
SOURCE: washer won't rinse and drain
check the door switch.you can bypass the door switch.you don't nead it.
Posted on Nov 28, 2009
ZJLimited
  • 17970 Answers
SOURCE: I have a 5500 series
NF code is a "No Fill" fault: this indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill.
You need to, first, make sure the water supply is turned on; second, if the water is turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. Also could try in this link the Consumer Display Table Code
The Maytag Neptune models (
front load Maytag washing machine) was made by Samsung, them its possible that this documents helpfull:
- Owners Manual -->> applianceblog.com/manuals/16026736.pdf
- Service Manual -->> applianceblog.com/manuals/16025909.pdf
Hope this helps you.
Posted on Mar 21, 2011
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
Rinse cycle
most new washers have a cold water only rinse be sure cold water hose is connected to cold side of valve and turned full on ..be sure to ck screen inside cold connection on valve for sand or some other restriction
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Elite top load washer timer will not rotate by itself through the wash/rinse/spin cycles
Gkar06,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Each portion of the wash/rinse/spin cycle work correctly, but you have to manually move the timer to each cycle.
This tells us the timer is bad and needs service to replace it!
You will be fine, it is not a big job!
If you like you can try this first!
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know!
Please remember to enter a rating before you leave.
Thank You
Sep 25, 2008 | Kenmore 24032\24036 Top Load Washer
Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
Dec 24, 2006 | Maytag Neptune MAH5500B Front Load Washer
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
