Question about Garden
John deere z445
Motor b&s 27hp will not start
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
mickey813
  • 472 Answers
SOURCE: John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Posted on Oct 15, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
  • 81 Answers
SOURCE: What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Posted on Apr 13, 2010
My john deere z445 won't start. makes ticking noise. what is the problem?
Confirm that engine will rotate.
Confirm voltage at battery during crank attempt minimum 9 volts at crank, 12 volts at rest.
Confirm greater than 9 volts at starter when cranking.
Jun 29, 2017 | John Deere Garden
Need to download free john deere z445 owner's manual
Try JD owners forums, someone may have a soft copy.
Apr 27, 2015 | John Deere Garden
Why does the battery go dead overnight after john deere z425
Need additional information...Check to see if it is the new battery or the electrical system first........ when the battery is "up", disconnect from the system. Remove both wires from the battery...connect the next day and see if the battery will crank the mower. I've experienced new battery's that have an internal short....Let us know whether battery or John Deere electrical system.....and we can troubleshoot from there...
Jun 16, 2014 | John Deere Eztrak Special Edition Kit Z425...
I need a deck belt diagram for a 08 john deere z445 52'' cut
http://manuals.deere.com/cceomview/OMM155509_L6/Output/Index.html?tM=HO
Oct 21, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
