Question about Dryers
Outlet and ceiling fan stopped working
Hello, I was using my vacuum cleaner and was using it fine, when all of a sudden it stopped working. I noticed the outlet that it was in stopped working as I tested it with several other items (i.e. lights, etc.)The vacuum cleaner was not affected. When the outlet stopped working I noticed that the lights on the ceiling fan and fan itself stopped working as well. I thought maybe it was a blown fuse but I tested it with a volt meter. I also was told by a Home Depot person to replace the affected outlet so I did, but no change. What else could I try?
    Genius:
  • 1,617 Answers
If it's not the breaker then I would call an electrician.
Posted on Jul 15, 2013
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
SOURCE: breeze ceiling fan not working
We have a 52" Aloha Breeze fan that stopped working this evening - fan and light. The remote control was burning up - after reading the other posts I hate to see what else is burning! Sounds like it would be safer to buy a new, reputable fan than spend more money on replacement parts.
Posted on Jul 16, 2008
SOURCE: ceiling fan with light fixture remote won't turn it off - help!
Think we've figured out that a neighbor has the same remote code as we do and we will have to change our code. (This fan is out on our screened porch and the homes are close together here.)
Posted on Oct 15, 2008
muttandjeff
  • 359 Answers
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Posted on Nov 27, 2008
  • 1810 Answers
SOURCE: Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Posted on Jul 29, 2009
How to repair my ceiling fan
The only way I see you can do it is wire nut the two yellows together. The yellow wire has to be in the connector for your fan to work.
Aug 17, 2014 | Dryers
How to wire ceiling fans
Some home depot guy bored?
Aug 17, 2014 | Hampton Bay Dryers
Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
May 29, 2014 | Dryers
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
Wobbly ceiling fan
Make sure the blades are not loose.
Jun 11, 2017 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
Hampton Bay Stopped Suddenly while running
The motor may just need a good blowing out. If you can remove the fans motor and use compressed ait it can be cleaned thoroughly. First tun the motor by hand to see if it spins freely. It may have a dried up bearing locking up the fans shaft to the motor causing it to have stop. YThe bearings have a flat colored seal which can be popped off to relube then snap the seal back in
Apr 10, 2010 | Hampton Bay 60 In. St. Regis Fan, Ancient...
My Hunter ceiling fan will only run on the lowest speed, we have two that stop working completely, I am not sure the serial number but it is 7 years old,and it has not worked in a couple of years. We was...
change speed selection switch . its faulty and has to be replace. do not attempt to open no servacable parts. check at the company or flee market for part it's a standard part.
Jul 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Stopped working suddenly. wont come back on.
try another otlet.if you have it plugged into a gfi outlet the little circit beraker on the outlet might have trippid if so push in on the red buttom till you hear it ckick.thatd resetting the gfi outlet.those kind of outlets can be found in thr kitchen,bathroom and outside.
Apr 16, 2009 | Oreck XLS700A Upright Vacuum
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
Dryers Logo
69 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
