Question about Vehicle Parts & Accessories
Sliding door driver side sliding door doesn't open with the push button and window doesn't roll down. how can I fix It? please any suggestion?
  • maria s Jul 15, 2013
    thank you for your help it is fixed
  • 7,627 Answers
Try the Cars & Trucks Category. It would be helpful if you posted your Make, Model and year of Auto.
Posted on Jul 14, 2013
Testimonial: "Thank you I will try my best"
I got a 2000 Pontiac trans am and every time I turn the car on the driver side window will roll down and it won't roll back up. But the passenger side window works fine. And when the stereo works the...
How about when the radio is on & the key is off or
in your hand,if you open either front door does the radio go off
& do you lose the delayed window feature assuming you have that
If so you problem is a delayed accy relay
Next would be the front door switches
I will give you credit for what you tried
but fail to see why you would switch motor
from door to door,they work powered directly or they don't
I would think your battery would have gone dead by now
if the relay failed to time out or go to sleep
Jul 27, 2013 | Cars & Trucks
I have a 2003 Chevy Venture. My passenger side window quit going up about a month ago, but I could still roll it up from the drivers side. Today my drivers window would not go up. I took the panel off the...
Had same problem and replaced switch on drivers door and now works fine. Not saying thats your problem but i went through the same stuff and that fixed it for me.
Aug 12, 2012 | 2003 Chevrolet Venture Passanger
2000 xterra driver side control panel-everything works but the driver side window. I can pull it up a certain way -hold my ****** out to the right & lean to the left and it will roll up. it rolls down...
Hi Wendy Lee,
It is possible that the window switch is going bad, but it is also possible that the window motor is going bad. Either way, you would have to remove the door panel to do any kind of testing. One very easy thing that you can do is contact your local dealership or search online for any recalls on that particular problem for your make and model. I do know that Nissan had a recall for this particular problem on the 2001 Xterras. Perhaps your make is included. If not, then trying a different window switch (new or used) will narrow the possibilities. If a different switch doesn't fix it, you can all but bet it's the motor. Compare prices from parts stores and junkyards. I hope this helps in some way.
Aug 17, 2011 | 2000 Nissan Xterra
I purchased a 98 chevy lumina sedan about 6 yrs ago. at that time, the driver's side power window would only go down about half way, at the half way mark, it would continue to "try" to go...
The widow regulator is bad. I believe yours is set up on a gear system. there is a long band that is plastic, of course that will lose teeth. The reason it stops. These are not hard to replace. remove the door panel. You will see the regulator and the track. You will need some tools and a drill to remove rivets. The track will pull out, then slide the new one in. you may have to remove the window to do this. Shop rate is 1 hour + materials.
Aug 16, 2011 | Chevrolet Lumina Cars & Trucks
2005 Dodge Ram...2 of my windows will not roll down not sure why. just the front driver side and the back passenger side what cld the problem be?
If they don;t roll down by pushing the buttons on driver's door, then i suggest opening the door panels and checking the power on the lines to the power window switch and the motor ( with a volt meter or a 12V light bulb), If you got power on the line to the motor then definitely the problem is with the motor and you might consider changing it. Hope it help, best.
Feb 15, 2010 | 2005 Dodge Ram 1500
Driver`s window works, all the other windows do not .
My Cherokee has a window lock button on the driver door (A child safety feature). See if your is locked... push the button and try your windows.
Hope this helps... Good luck!
Sep 25, 2009 | 2004 Jeep Grand Cherokee
2005 F150 Lariat Rear power window not working
i also have a rear power window that wont open..I just got the truck and it was like this when i got it... My windows work just fine but my rear sliding has zero responce when i press the button. Do you think its the 30 amp breaker?
Jun 20, 2008 | 2005 Ford F-150
Vehicle Parts & Accessories Logo
174 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
