Question about Hayward 250kbtu Ng Pool Heater - Inground
H250fd. I have the service light lit when I turn the system into standby and shut off my pool pump. Is this normal?
Is there are problem when the service light is on?
    Problem Solver:
  • 12 Answers
This is not normal. You have some sort of electrical short. Possible bad fuses, wiring, or board if its not showing a code on the display
Posted on Jul 19, 2013
2 Suggested Answers
  • 246 Answers
SOURCE: When I turn on my pool ,the heater wont turn on.
clean the filter turn breakers off for twenty secons
Posted on Sep 11, 2009
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
Aug 08, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Intex pool pump runs for five minutes and then shuts down and service light comes on. What could be the problem as it was running fine the day before?
We don't have a service light on our pump, but usually when our is playing up it's because the pump is struggling to push enough water through - for example if the filter needs changing or if the skimmer isn't receiving enough water/water level is too low.
Nov 04, 2013 | Intex Automatic Salt Water System for ...
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Tiger Spa I have reset the powere at the panel and the spa apperes to go on. I run the pump for a while and then turn the pump off. The power light begins flashing and the pumps will not restart. It...
Have you called your local Watkins dealer for a service call?
I can have you look at a couple of things before you call it in.
Once you turn the system on it will operate without the heater on to purge the system of air. Once that few minutes has gone by the heater will turn on and they system will operate normally.
At what point during this cycle does the system shut down? Does it blow the circuit breaker? Exactly HOW does it shut the pump down?
Rod
US Parts Center
Jan 19, 2013 | Pool & Spa
Turn heater for pool while pump in on, everything is fine, pool heats then when timer stops pumping, the heater will stop but the digital temp climbs,on display and eventually goes on the display...
When the system shuts down the water inside the heater collects residual heat in the heater. For most systems that have intermatic timers (yellow dial) you can get a fireman's switch kit that will shut the heater off about fifteen minutes before the pump goes off to let it cool down. If you have electronic controls you should have one built into the system and will just have to activate it.
No promises but this could cause problems with time.
Oct 30, 2010 | Sta Rite 200k Btu Nat Gas Heater Maxetherm...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My Hayward pool 350000 heater will light and stay lit and heat the pool for a while, but will just shut off including the pilot light. When I re-light it it works for a while again and then shuts off...
Sounds like the pilot assy needs to be replaced. It has 2 functions one is to light the main burner but also to let the system know that the burner is lit. If it thinks the burners are not lit it turns the gas off
Jun 23, 2009 | Hayward H Series Millivolt 250,000 Btu...
On light does not glow and can not "stop" the system
the rain shouldn't have hurt the control panel. it sound more like damage due to lightning.
Jun 07, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Hayward 250kbtu Ng Pool Heater - Inground Logo
63 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
