Question about DeLonghi EW0507 Oil Filled Radiator Heater
Burnt plug my delonghi's plugin sparked and melted the end of the plug causing my socket to not work and lots of smoke. was wondering if there was any recalls on this oil filled radiator heater.
  • mrscow Aug 28, 2007
    i am still waiting to hear from you if there is a recall on the delonghi ew0507 oil filled radiator heater.
  • Albert Stoll
    Albert Stoll Oct 18, 2017
    This URL has the brand and model numbers of the DeLongi Oil Filled heaters which are in recall. http://www.heaterrecall.com/
  • 625 Answers
I will check, meanwhile go to the hardware store and get a replacement plug for it. the cord has a ribbed conductor and a smooth conductor. the ribbed conductor goes on the brass screw on the replacement plug. the smooth one goes on the other.
Posted on Aug 29, 2007
SOURCE:
Could a faulty ECM or PCM cause heavy white/blue/grey smoke when starting?
no ---smoke or steam if only on start up on cold mornings could be considered condensation that has accumulated in the exhaust but if continues for a while then you have an engine problem white -usually indicates steam coolant being burnt ---blue is oil usually head problem or blow by on pistons --whitish grey transmission fluid -- black carbon fuel or needs tune up -look at oil level and if oil milky chochlate color coolant getting into oil from possible head gasket -pull the plugs and see if any fouling is shown and do a coolant pressure test
How To Read Spark Plugs Pictures Yahoo Video Search Results http://www.arcticchat.com/forum/attachments/z-zl-zr-zrt-tcat-ext-jag-cougar/221925d1359305476-read-my-plugs-plugs1.jpg
Oct 16, 2016 | Mazda Protege Cars & Trucks
2004 Suzuki intruder 1400cc keeps burning a plug what could be the problem
I assume you mean spark plug? Have you got the correct spark plug? Different plugs have different heat ranges , you may have to go to a colder plug. Check the spark plug lead as well. It may be causing a misfire. it could be the fuel you are using. If its a burnt oily plug, You may have a broken piston oil control ring or a faulty valve causing oil to seep into that cylinder. Does it blow smoke when revved up or does it go through a lot of oil between changes. Do a compression test on that cylinder.
Jul 01, 2015 | Suzuki Motorcycles
While driving my dashboard displayed the warning sign for oil. the oil level was correct, but still it is rough on idle and makes a lot of smoke. how may i diagnose the problem?
Bummer deal! Rough idle and black smoke indicates a possible bad fuel injector leaking gas - or failing spark plugs. Bad or dirty injectors are a cause of sticky valves, and when sticky do cause rough idle and sometimes valve tapping - beside black smoke. Check those items first as they are most common failures. Rarely, a engine head sealing gasket may leak coolant into the motor to cause such problems. That would make a white steamy smoke. In that case it would overheat - did it? In this case, serious engine work, or a new engine is needed. I like the products at this web sites to end those issues. Hope this helps. DIY fuel injector cleaners fast acting Ends several tune up problems
Nov 04, 2014 | Cars & Trucks
White smoke delica
The thick white smoke is either burnt oil or steam you can easily identify the smell of burnt oil not really sure why you thought it would be a good idea to put a 2 stroke mixed fuel in but more than likely that alone fouled your spark plugs. But if the problem preceded the fuel blunder then your either have a bad intake/head gasket, leaking valve seats, or bad main engine seal. Replace the spark plugs and check cylinder compression. Change your engine oil and check to see if it contains water/coolant also watch for coolant or oil consumption
Apr 12, 2014 | 1996 Mitsubishi Delica
Plugged 120V appliance into 220V socket
Its dead, and whatever you do, DO NOT plug it into any power again, it could cause a fire so fast that you would be in mortal danger.
Most of the world uses 'real' levels of power, your american appliances cannot handle it.
Dec 19, 2013 | Blenders
1987 Kawasaki KDX 200 lost compression
Hi, Anonymous and the usual suspects are:
1. Broken or hole burnt through piston due to spark plug heat range to high or pre-ignition due to the ignition timing too far advanced overheated engine caused by a burnt valve or carbon/metal particle embedded in the cylinder head glowing hot causing abnormal combustion timing.
2. Failed power valve due to extreme heat.
3. Broken connecting rod due to bottom end failure.
4. Catastrophic piston ring and ring land failure.
5. Spark plug blew out of head due to improper torque or failed threads.
6. Failed compression release valve or blown out like the spark plug scenario.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KDXRIDER NET View topic Compression Test
What should the compression be on 1989 KDX200
Kawasaki KDX200 Service Manual
OEM Parts for Kawasaki
1988 Kawasaki KDX200 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 08, 2013 | kawasaki Motorcycles
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
HI, the freezer is tripping out the fuse box and there is a burnt and melted area on the plug that goes on to the 'black bottle' in the bottom of the freezer. is it possible to get a replacement...
just replace the plug as you would any appliance that comes without one.a loose connection/socket is a prime fault for heat buildup and cause the connection to melt.
Nov 05, 2010 | Refrigerators
Extension cord is black delonghi cf210)
well , yes , it could be fixable , but first the adapter is a three prong to two prong adapter ? if so , for your safety I recommend to plug A/C UNIT wheres a three hole outlet , using the adapter eliminate the UNIT to be grounded , there for causing problems like cord getting hot. hope this helps
Apr 27, 2008 | DeLonghi CF210 Portable Air Conditioner
Open Questions:
See all DeLonghi EW0507 Oil Filled Radiator Heater Questions
DeLonghi EW0507 Oil Filled Radiator Heater Logo
618 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
