Question about Plumbing
AquaSource kitchen faucet handle won't stay up
  • 374 Answers
SOURCE: How do I disassamble my one-handle kitchen faucet?
First ensure you have shut the water supply off at the stops- the small valves located underneath most plumbing appliances. Since we are speaking generically my comments may be a bit different depending on make and model. Most single handle faucets have a snap on cover over the base where the handle connects to the valve base. Pop this cover off and it will expose a screw that holds the handle onto the valve cartridge.You will need to remove this screw this will expose a nut/retainer that holds the cartridge in place- remove this item. Now will be able to pull the cartridge out using a pair of pliers. If the cartridge will not come out most home repair stores sell a cartridge extracting tool. This tool is a tee handle device that screws into the cartridge and has a nut that one tightens to break the cartridge free of the valve body. Some extreme cases will require some extreme pulling and snatching on the Tee handle to get the cartridge out. I personally dry the interior of the valve body a apply a thin coat of grease/lubricant to improve the service life of the new cartridge. Hope this is of assistance to you and thanks for using Fix Ya. If I can be of anymore assistance please let me know.
Posted on Oct 08, 2008
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
SOURCE: 533-50 kitchen faucet leaks above base mount at
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
I have a aquasource faucet and the top button is stuck
Unfortunately, Aquasource is an imported faucet by Lowe's, and parts are not easy to get. You might want to visit a Lowe's and see if they have a replacement diverter unit for this faucet. If you can get one, it should take about 10 minutes to install, then you'll be like new again.
May 08, 2014 | Plumbing
Aquasource 2 handle Kitchen Faucet with sprayer as a fourth piece
I recently installed one and the center is the "holddown" hot and cold were just the hose feeds to faucet. There was a ring in center that had two screws up to base from underneath sink (hex key). Remove center ring and wiggle whole unit up and out. Dont forget to turn off water main and drain lines beforehand. Have fun.
Mar 10, 2014 | AquaSource Stainless Steel 1-Handle...
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Two handle Moen kitchen faucet. Hot side handle
loctite is an excellent product,but you have to have a couple of threads for it to 'lock'! be sure handle is seated[pushed all the way on] or shop a hardware or home improvement store for a replacement screw or a 'self tapping'' screw of the proper size.
Sep 26, 2009 | Moen & Monticello& Two Handle Lavatory...
Plumbing Logo
109 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
