Question about Acer 22" X223w LCD Monitor
How do I reset to factory settings for acer 22" X223w lcd monitor
Fix-4U
  • 293 Answers
SOURCE: Text ghosting on Acer 22" widescreen monitor
Hi...there,
It's seems you need to reset your WB (white blance). Open your on screen display and look for WB settings... Good lucks!
Posted on Oct 07, 2008
SOURCE: No audio from my Acer monitor
The Acer 223W does not have built-in speakers; this explains why you can't get audio from it. You're better off buying a set of speakers anyway, monitor speakers are generally about as good laptop speakers... meaning they are not very good.
Posted on Apr 14, 2009
  • 8 Answers
SOURCE: Acer x223w - no option to goto 1680x1050
It would seem, somehow, your graphics driver was corrupted. The only thing to do is re-install graphics drivers. These can be found with a quick Google Search: CLICK ME
The first link, to DriversCollection.com, looks promising. This one is for Windows Vista or XP, but you need to specify on the tabs near the top of the page. Make sure you download the correct driver, as this page includes other drivers. You're looking for "Graphics Driver" [Vista] or "Video Driver" [XP].
Hope this works for you.
~Chris
Posted on Jun 11, 2009
budmrtn
  • 11361 Answers
SOURCE: Acer Monitor Lcd 22 in X221w LCD Monitor
You need to check the power secton to see if you do have 5vdc (for logic) and 12~18vdc (for backlight inverter) in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 11, 2010
  • 89 Answers
SOURCE: my acer x223w lcd monitor is flickering. When I
hi, have you checked running the monitor on all the outputs? dvi? vga? flickering is caused most times by bad connections either in the video cable, or on the video board, or power board inside the monitor. i know those monitors pretty well, i'm willing to bet if you opened up the monitor and looked at the power supply board, you would probably find worn/blown capacitors. this could very well account for the flickering. electrolytic capacitors store power for parts of the circuit that require lots of power to run. when they go bad(overheat) they pop up at the top, sometimes leak a little fluid. they are replaceable, need to be soldered in, and you can find them at most electronic stores abundantly, but you should check everything else first, the video cables(dvi,vga) before opening the monitor.
Posted on Jun 18, 2010
My acer x223w monitor goes black and the blue light stays on what could it be??
The backlight controller has failed. It can be repaired or replaced.
Feb 20, 2011 | Acer 22" X223w LCD Monitor
My monitor hibernates after a few minutes..how do I reset it so it won't do that? How do I set the brightness?
Click Start
Click Control Panel
Click Power Options
Change the setting for the monitor from a "few minutes" to "60 minutes" or to "never".
Sep 20, 2010 | Acer 22" X223w LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Power button blinking on and off. Not powering up. Acer x223w lcd monitor.
it means your monitor doesn't receive any signal from the system unit, have you check its connection? or RAM, or your video card? try to clean your RAM with a pencil eraser like wise with your Vcard, maybe one of them is busted. Now replace it
Mar 04, 2010 | Acer 22" X223w LCD Monitor
No inlet on my computer for my X223W LCD Monitors audio cord.
Is the monitor supplied with inbuilt speakers..? Most monitors no longer have inbuilt speakers and this is why there is no place to connect the audio cable. You will have to purchase a set of external speakers and connect these to the audio output of your system.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
I can't open the user guide off the disc for my X223W LCD acer Monitor
Ah.
Is there any error message?
Should be an PDF file. Is Adobe Acrobat Reader installed or any alternative PDF Reader?
Download User Manual Acer X223W (zip file)
Jun 11, 2009 | Acer 22" X223w LCD Monitor
No sound
Yes, you do. You need an stereo audio cable. It will have a connector like found on portable headphones on each end.There should be a recepticle for it on your monitor, usually marked light green. This cable would then connect to your computer's audio output. Although, I don't think your monitor has speakers.
Apr 10, 2009 | Acer 22" X223w LCD Monitor
check that the green audio cable is plugged in properley it does click a couple of times on its way in.
Mar 18, 2009 | Acer 22" X223w LCD Monitor
Acer x 223w monitor and what video card
I have not answered the question about this problem, however someone else told me that I would have to change my graphics card to take full advantage of the features of the X223W monitor. But they did not know what I had to change it to.
Jan 18, 2009 | Acer 22" X223w LCD Monitor
Open Questions:
See all Acer 22" X223w LCD Monitor Questions
Acer 22" X223w LCD Monitor Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
