Question about Kenmore 420 Series Water Softener
Error 3 on screen - Kenmore 420 Series Water Softener
    Problem Solver:
  • 27 Answers
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Posted on Jul 16, 2013
What is left to check. Shuts down with error code 13 after 2-3 min.
Whats the error code? You should first look that up on their site, and ask further questions here.
Dec 02, 2015 | Rheem RTG-66DVP Direct Vent Liquid Propane...
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
Nov 22, 2013 | Rheem EcoSense by 4.2 GPM Tankless Water...
I have a Ecosense.... My tankless hot water is not working it turn off when i use it for 2 to 3 min
Most likely the heat exchanger has build up in it, the unit will need to be flushed with descaler. But refer to the owners manual or behind the cover of the unit to confirm the error code. Good luck.
Nov 05, 2013 | Water Heaters
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
My water heater is flashing a cod 2 then 3 how can i reset this i lost ths manual
First thing to try for any electronic problem is unplug the machine and see if problem resets.
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual and Rheem chat and contact:
Error code 2 and 3 do not show on Rheem/Paloma charts or in typical manual.
Error codes are generally considered start places for troubleshooting.
Multiple error codes can mean PC board failure, but same problem on one unit can have different cause and solution than another unit.
Read the manual and make sure yearly maintenance is caught up.
Add a comment and say what you did to solve problem.
Jun 13, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Rinnai Tankless won't stay on
how far is the tankless from the gas meter? error code 12 means it doesn't have enough gas running to it. is the 3/4 flex true 3/4 or is it 1/2 with 3/4 threads. have you checked your BTU load on your house to make sure your 1'' pipe can handle everything else you have on the house? sounds like to me you dont have the right amount of gas to the unit.
Sep 29, 2009 | Rinnai Webstone The isolator EXP tankless...
Error 11 no natural gas
if you don't have a 3/4 line from the meter with 2lbs and a regulater on it the 3/4 line is for volume and the regulater if for surging and making sure it doen's go below the volume of gas needed. if you have this you will have no problem, if you don't you have a problem good luck
Jun 07, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Kenmore 420 Series Water Softener Logo
43 people viewed this question
Top Kenmore Water Heaters Experts
Dennis
Gene Haynes
Tom Chichester
Are you a Kenmore Water Heater Expert? Answer questions, earn points and help others
