Question about Bosch Ovens
Bosch hbn 41 oven trips every time i turn the oven on
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 27 Answers
    SOURCE: INSTRUCTION MANUAL
    you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
    Posted on Mar 09, 2009
    Why wont fan turn off after use in oven bosch model hbn 13n5,1b
    It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
    Sep 03, 2014 | Bosch Ovens
    Bosch HBN 91 Sticky Fan
    Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
    Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Bosch oven glass
    http://www.bosch-home.co.uk/store/spareparts/search
    Feb 20, 2013 | Bosch HBN 9061 / HBN 9021 Double Oven
    Instructio manual for a Bosch oven HBN 574850
    http://www.bosch-home.co.uk/customer-service/download-product-manuals.html click on link, open new window as indicated and type in the ENr number without spaces, you can then download the manual (IU is user manual, II is installation instructions)All the best
    Aug 29, 2011 | Bosch HBN 742 / HBN746 Electric Single...
    My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
    Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
    Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
    INSTRUCTION MANUAL
    Feb 23, 2009 | Bosch HBN 131560B / 131520 hot-air...
    Bosch hbn s gb
    oven element would need model and ENR No. to supply
    Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Bosch oven HBT346 - how do I reset the clock?
    Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
    Apr 15, 2008 | Bosch HBN 442 / HBN446 Electric Single...
    Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
    Ovens Logo
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
