My sears kenmore washer model 11021302012 will not wash
It will only sensor but goes no futher, will not wash.
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
Sea Breeze
  • 4654 Answers
SOURCE: What's value of Sears Kenmore washer, model 110.49722992?
$55.00 US dollars
Posted on Feb 26, 2009
SOURCE: Sears Kenmore Calypso Washer
Usually "FL" means one of two problems, both with the drain system. The good news is that both are relatively easy to fix yourself. "LD" can also be fixed by doing the following as well.
First, get the washer somewhere outside, in a garage or basement where you can afford to have large amounts of water spill out onto the ground. It may be easier to dismantle the inside of the basin and get as much of the water shop-vac'd out before you move it. Once it's outside, open up the back panel, and on the bottom left you will see a large black hose with clips on either end. Take the clip that attaches the hose to the bottom of the tub off and all the left over water will spill out. Turn it on it's face now, take the bottom panel off, and remove each of the clips on the hoses (drain hose to) and make sure nothing is blocking any of the lines. If it is, then remove it and this MIGHT fix your problem.
The other option (if the previous doesn't work) is to replace your pump motor, because odds are it has gone bad. The Calypso washers are notorious for having drain issues, and there was even a class action lawsuit a few years back that would have likely allowed you to get the washer fixed for free. If you do need to get a new drain pump motor, they go for anywhere between $80-100 and are a breeze to switch out. Hope this helps.
Posted on Mar 11, 2009
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
  • 401 Answers
SOURCE: Sears Kenmore series 80 washing machine stops after wash cycle
Sounds like the lid switch.
Posted on Jan 02, 2010
I have a Kenmore vmw washer (made by whirlpool) mod 11021302012. It empties but does not spin.I cannot turn the drum from the bottom or the top. On the belt guard, there are greasy rubber shavings.
Pull the top off the cabinet, check and make sure there is nothing stuck between the drum and the tank. If there is nothing then you need to pull the drum and check the bearings and the gear case.
Sep 23, 2016 | Kenmore Washing Machines
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
Many Kenmore appliance manuals are available from the Sears Parts Direct site: http://www.searspartsdirect.com/ . The manual page for the 110.21102011 washer is http://www.searspartsdirect.com/partsdirect/user-manuals/11021102011-Kenmore-Parts-Washer-Parts-manual?searchTerm= if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/1009787L.pdf if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: http://www.searspartsdirect.com/kenmore-parts-washer-parts/model-11021102011/0582/0153200.html?searchType=modelSearch&prst=&q=11021102011&searchTerm=11021102011&shdPart= . The agitator is shown in the Basket and Tub Parts diagram: http://www.searspartsdirect.com/kenmore-washer-parts/model-11021102011/0582/0153200/K1103004/00003.html .
I hope this helps.
Jul 30, 2015 | Kenmore Washing Machines
Can the motor sensor,motor and bearings be replaced at what coast?
Of course the motor can be replaced. I don't think you have a motor sensor on a top loader. What bearings are you talking about? Normally the motor coupler wears out many times before the motor goes bad. The coupler connects the motor to the transmission. Go to www.sears.com/parts and put your model in and you'll see all your parts.
Aug 28, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Sears washer model 417.43042200 won't agitate or
This is typically a sensor issue. If the door sensor is malfunctioning, this will cause the washer not to enter the wash cycle. The wash motor is separate from the drain motor, so this may also be a control board issue. Contact Sears, as the control boards are typically under warranty longer than other parts.
Feb 24, 2010 | Kenmore Washing Machines
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore 23822 Top Load Washer
Need replacement coupling for Kenmore Washer
Go to a sears service senter and they can order one for you
Jan 22, 2009 | Kenmore Washing Machines
Oct 13, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
