Question about Vehicle Parts & Accessories
Chrysler town and country 2008
How to fix headlight
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
hunterd777
  • 14 Answers
SOURCE: Early wear on front brakes /rotors for 2008 Town and Country
I work for a brake repair shop and trust me you are not alone.Enterprise and alot of other people bought the same van and had the same trouble.I hate to say but it doesnt stop there.About every 14 to 15 thousand miles you have to replace the front pads.As of now they dont have an upgrade,for instance ceramic pads, but I am sure they will very soon
Posted on May 01, 2009
keemo68
  • 1263 Answers
SOURCE: radiator fan relay,2001 chrysler town country
the relay is located in the power distribution box under the hood the relay will be a square black or gray cube just pull out and make sure you rerplace it with the same type relay. refer to your owners manual for any questions regarding the fuses and relays
Posted on May 08, 2009
  • 1986 Answers
SOURCE: how to replace our low beam headlight on 1999 town and country
1.) Open the hood of your van 2.) On the passenger side of the vehicle, look behind the headlight enclosure. You will see a set of wires running into the back of it. This is the power clip. Either with your hand or a flat-head screwdriver, pop the power clip off.
3.) There is a plastic ring encasing the light bulb. Turn the ring counter-clockwise and pull it out of the socket and set it aside.
4.) Pull firmly on the light bulb to remove it.
5.) Place the new light bulb into the same opening. Be careful not to touch the glass part of the new bulb. The oils in your skin can substantially reduce the life of the new bulb.
6.) Replace the plastic ring and turn it clockwise to lock it in place.
7.) Reattach the power clip to the back of the bulb.
Posted on Oct 29, 2009
  • 1986 Answers
SOURCE: Chrysler town country 1996 headlight
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Posted on Nov 04, 2009
SOURCE: reset odometer after oil change 2008 chrysler town
Chrysler 2008 Town & Country 4.0L engine. Message center says Oil Change is due. How do you reset the message after changing the oil?
Posted on Jan 09, 2010
2004 Chrysler Town and Country won't start. Lights, radio and horn works just fine. Even put in a new starter and still get nothing. Ran a wire from battery to the starter and got a little kick.
Chrysler Town & Country Questions - My van won't start ...
www.cargurus.com > Questions > Chrysler > Town & Country
CarGurusSep 29, 2008 - ckf2004 answered 4 years ago. I have a 96 chrysler town and countrylx and the engine died, turned over but wouldn't start, I researched and replace the flywheel .... My van sometimes won't start because it kills the battery.
My town & country 2004 wont start sometimes - CarGurus
CarGurusMy town & country 2004 wont start sometimes - My van start doing something really weird. it will ... Asked by TownCountryguy May 03, 2013 at 03:31 PM about the 2004 Chrysler Town & Country Base .... Sometimes you tap it & it won't work.
Van won't start - Chrysler town and country - YouTube
? 1:01
https://www.youtube.com/watch?v=mkEL2vlLZr0
Jun 26, 2014 - Uploaded by Philip Walker
We have the same issue currently...very randomly...with our 2008 Caravan at the moment. Wife just got ...
2011 Chrysler Town & Country Engine Won't Turn Over, Will ...
www.carcomplaints.com/Chrysler/Town_Country/.../engine_wont_turn_...
The 2011 Chrysler Town & Country has 34 complaints for engine won't turn over, will not start. Average repair cost is $902.00 at 58178 miles.
Jan 14, 2016 | Chrysler Cars & Trucks
Tip
How To Install Replace Headlight and Bulb Chrysler Town and Country 05-07...
How To Install Replace Headlight and Bulb Chrysler Town and Country 05-07 1AAuto.com
on Apr 04, 2012 | 2007 Chrysler Town & Country LX New Cars
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
Dec 16, 2015 | 2004 Chrysler Town and Country
On a 08 town and country van why do the headlights go out as you're driving
Sounds like a short some where. Vehicles are made so if the lights have a short they will go out and back on for a few seconds for safety getting off the road. They come on to stay when it cools down then goes out when it heats up.
Sep 23, 2014 | 2008 Chrysler Town & Country
Headlight goes on/off
I think it is a loose connection. If you know how to access the headlight bulb(s), gently, with a soft cloth check if bulb is loose. if so, gently tighten it and you are ok.
Jul 15, 2013 | 2008 Chrysler Town & Country
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
