Question about Dynex 32 in. LCD Flat-Panel HDTV
Lcd bulb replacement instructions - Dynex 32 in. LCD Flat-Panel HDTV
    Top Expert:
  • Dynex Master
  • 75,581 Answers
If you wish to get more instructions about bulb replacement, check the site linked here. It has details with illustrations. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Posted on Jul 15, 2013
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
How do i replace a bulb or lcd screen on akai s3000
If you can see something, but very dim, it will be the backlight. search well known auction site for replacement with plug in lead, will require no more than a philips screwdriver to repair. Instructions with part
May 18, 2012 | Televison & Video
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
How do your replace the clock bulb on the CRV 2001
There is no bulb for the 96-01 CRV clock, it is LCD based. If the fuses are OK (radio working etc) then the clock module is defective. I offer an affordable repair solution, check out www.autoclockrepair.com. I have removal instructions there as well.
Jun 20, 2010 | 2001 Honda CR-V
Where I can get instructions that how to replace Sony VGN FW170D display? and best web site to buy display. I gotcrack in my display, only half of the display works.
http://computershopper.com/laptops/howto/replace-your-laptop-screen
This website can instruct you on that. Isntruction are for most if not all laptops. It is fairly easy, just be careful and do not rush it.
NewEgg.com is a great place to buy the best and cheapest component to your computer hardware needs.
Oct 16, 2009 | Sony VAIO Notebook
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
Bulb Replacement
the bulb hot indication has nothing to do with the lamp counter.u would have reset the counter as suggetsed by the manufacturer,
this problem is because of the following:
1) wrong bulb
2) cooling fans not working adequately
3) defective ballast
check the above for a solution
Jan 08, 2009 | Toshiba Replacement Projector Bulb...
How to replace my backlight, for a compaq 2500
Your laptop's LCD is illuminated by cold-cathode bulbs, often times a specific size for fitting purposes within your laptop's screen (as size constraints and cosmetic differences can leave little to no room withing the top lid for standard bulbs).
Replacing the back-light bulbs requires the original parts, or replacement as approved by the manufacturer. The first place I would start would be contacting HP (who now owns compaq) at 1-800-hpinvent and inquiring as to the cost for just a replacement screen for your model. Otherwise, you can order one from eBay or some other similar online resource.
The actual installation is quite simple, but it requires about 15-20 minutes of time, and three or four specific tools.
You have to disassemble the top lcd beveled casing, you have to detatch the lcd from the video flex cable that runs through the hinges of the unit and underneath the keyboard bevel. And re-attatch all said parts when you are complete. Keep track of the screws you remove in order to release the casing. And on the screen, often times those little rubber dots along the LCD screen actually need to be removed to locate several more screws.
That solution is if you purchase the entire LCD replacement contained together, which can be considerably more expensive than just replacing the back light. But finding the compatible parts to replace your LCD's defective ones might be close to impossible.
A quick search to help explain the process of replacing the cathode bulbs brought up this website via google:
http://www.inventgeek.com/Projects/shorts/overview.aspx
It has pictures that help illustrate the process for a standard screen. You would modify the instructions for your laptop's LCD screen.
If you do purchase a replacement LCD kit, you can always bring it to a Geeksquad technician and request an estime, or shop around to find a certified repair center that will install it for you.
Hope that helps.
May 01, 2008 | Computers & Internet
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Dynex 32 in. LCD Flat-Panel HDTV Logo
81 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
