Question about Garden
UP00608A need primer bulb
When i press the primer bulb in it want pop back out why?
The thing to understand is that this is not a primer, it is a purge and there is a big difference, a primer pushes fuel into the carb, a purge pulls fuel from the carb and dumps back to the tank, so when the bulb is pressed in, fuel in the bulb is pushed back to the tank, when the bulb comes our fuel is sucked from the carb, if the bulb stays in either the filter in the tank is blocked, or the fuel hose is trapped, or the filter in the carb is blocked, or somebody has fitted the pipes on the carb round the wrong way.
May 22, 2018 | Weedeater Garden
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
My washer will start but only run for a few seconds......unless you hold the primer bulb in
The primer bulb has a pin hole in it:
This is what you need:
http://www.mymowerparts.com/partdetail/1079/14606.php
All local lawn mower repair / parts sources have this part in stock. This is a common issue with primer bulbs that you have to hold the bulb in so that it will run. When you do that your stopping it from drawing air through the hole in the primer bulb so it operates normally. Replace the primer bulb and it will be fine.
Thanks for choosing FixYa,
Kelly.
Aug 14, 2011 | Briggs & Stratton Gas Pressure Washer...
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
The primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Jul 18, 2009 | Garden
I have a broken primer bulb for an Echo CS-3400 chainsaw. I need to replace it but am not sure how to remove the old bulb. I can access it but am not sure if it will be necessary to remove all the guts of...
You should be able to get to it if you just take off the cover that surrounds it. If you do not yet have a bulb purchased, I would reccomend trying the site I have below. I have also put the part number you will need to enter in the 'Search' box on the site to get the right bulb.
web site: www.m-and-d.com
Part #: ST-615-811
Mar 06, 2009 | Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
