Question about Summit Appliances Division SPWD1470C Front Load AllinOne Washer Dryer
E11 error I just moved into an apartment with this appliance and I tried to do a load of laundry and there is an E11 flashing error and it wont continue the rinse cycle...Can you help!?!
It freezes on the cycles
Good Morning Juan,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000E, freezing on the cycles and giving you an Error message 11. The E11 states that fill time is too long. There are a couple of things to check in this case. First, you will want to reset your appliance by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power you can start a cycle and see if it works. If it does, there just might have been some miscommunication between the different boards inside the washer. If it is still giving you the E11, you will want to make sure that the water pressure is at least 30 PSI. Make sure you're not using any other water sources while using the washer. Also make sure that the faucets are fully opened going into the appliance and that the hoses are not kinked in any way. If you are still having trouble receiving that E11, I suggest contacting the manufacturer for further assistance. Hope this has helped.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire Affinity ATF7000E Front Load...
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
F51 diagnostic code meaning motor RPS failure. However, upon running a diagnostic test... everything works properly and goes to the 'done' setting. Also, when doing a load of laundry the machine...
There actually is a class action law suit against whirlpool for this error code well not the error code but the machine itself. I have also had the unfortunate task at one point of fixing this error code. It basicly comes down to replacing the rps sensor, the stator which is the motor, the control board, and in my case I even had to replace the wire harness from the rps sensor to the control board as well. I would try calling whirlpool and see if there are able to provide any support for the machine. Hint while calling them stateing that all you household appliances are whirlpool as well seems to add some leverage. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation. I await any questions that you may have. Thanks Rick
Sep 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
When the wash has been done, and UE comes up, what does that mean?
Hello
Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Move the washing around inside the washing machine to create a more even distribution of weight
Apr 01, 2011 | LG WM-2277HW Front Load Washer
I have an Lg turbo drum machine it has filled up and done the wsh but then gone ue overloaded but i have removed all the clothes and it still wont empty the water or spin
"UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weightif you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Jan 26, 2011 | Washing Machines
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
E11 error. I purchased this camera used and can not get the camera to start. A indicator lite flashes green for a few seconds then red/yellow and shuts down. I have removed the flash memory card and...
Error Code "E11" on Kodak Digital camera means that the battery needs replacement. If replacing the camera recommended battery AA 1.5 volt alkaline or AA 1.2 Ni-MH rechargeable battery still error "E11" the camera needed to be service.
Nov 20, 2009 | Kodak DC290 Zoom Digital Camera
I have an LG washer dryer (model 12126rd) and it has just cme up with either UE or VE on the frint LCD panel. What does ths mean? Thanks!!!
UE means imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Resolution: Move the washing around inside the washing machine to create a more even distribution of weight
Oct 25, 2009 | LG WD-12126RD Front Load Washer / Dryer
Hi my LG 8kg top loader washing mashine says UE and wont drain
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Oct 19, 2009 | LG WFT1071TP Top Load Washer
Laundry appliance installation
not recommended may cause vibration issue.. my preference ? concrete or tile especially on front loads
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Summit Appliances Division SPWD1470C Front Load AllinOne Washer Dryer Logo
23 people viewed this question
Top Summit Appliances Division Washing Machines Experts
Are you a Summit Appliances Division Washing Machine Expert? Answer questions, earn points and help others
