Question about Dryers
Seville classic tower fan model 10177 review
Fan switches on for a few seconds, but then switches itself off. repeated attempts to start it again result in it not coming on at all...
SOURCE: casa vieja probe ceiling fan
one of the wires had disconnected and this seemed to cause the problem.
Posted on Feb 16, 2008
SOURCE: Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Posted on Aug 22, 2008
videotransmi
  • 105 Answers
SOURCE: how to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Posted on Mar 22, 2009
FixinFax
  • 3085 Answers
SOURCE: HOW DO YOU CLEAN THE INSIDE OF THE SMALL PERSONAL SEVILLE
Put it in the dishwasher, leave it in the sun for 2 days to dry out.
Posted on Apr 15, 2010
SOURCE: I have a seville classics
Good Luck!! I too have one and although I was able to take off a bottom panel and clean it- the important area (fan) proves quite inaccessable. I am very mechanically adept too. Either way felt it was a lot of trouble for nothing- so I used a powerful vacuum blower to blow out all the dust instead. When these fans can be purchased for 50 bucks, new, at Cost Co, it sort of eliminates the need to get real carried away with maintenance.
Posted on Dec 01, 2010
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Where is the fuse located on the Seville Classic tower fan model 10199.
https://www.sevilleclassics.com/uploads/products/pdf_20120315132254_Tower%20Fan.pdf
Although the link is for a 10127 fan, page 2 will show you the fuse, which actually in the plug. Hope this helps....
May 11, 2014 | Dryers
My Bionaire Tower fan is Switching the sitting by itself from 1 speed to 2 speed. is it a defect?
I don't think it is a defect, but you may want ot check with the store.
I have a similar one that starts at a higher speed and switches down to low after a few seconds.
After that I can select the running speed.
Mar 31, 2011 | Bionaire Tower Fan w/ Ionizer and Remote ...
I have a seville classics tower fan. How do I take it apart to clean it?
Nov 12, 2010 | Dryers
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
My fan makes a loud squealing noise upon starting
open the tower if you can and check if some obstruction of wire is there or not. caution turn of the pwr before doing that . if no obstruction then the fan has to be replaced. open the fan carefully take it to best buy or wallmart and get it replaced.
it is possible for the older computer that the fan goes bad or moves faster than its normal speed . its a common problem with all brands of computer.
May 07, 2010 | Seville Classics MSC10166 Tower Fan
The fan fuse 1.5A/250V is keep blown up as soon as
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Jul 02, 2009 | Seville Classics MSC10166 Tower Fan
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
