Question about Refrigerators
Rb195acbp back panel icing over - Refrigerators
    Sergeant:
  • 363 Answers
Sounds like the defrost timer is not working, take the model no. to a parts dealer to find out a price and see if you can replace it. You can try to turn it before you do to see if it may just be iced over. Rb195acbp back panel icing over - 7_16_2013_10_39_09_pm.jpg
Posted on Jul 16, 2013
Water is standing in the bottom of refrigerator under the crisper doors. Where is it coming from?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer
May 23, 2014 | Samsung RB195ACBP
Loud noise and ice build up on the back panel of refrigerator
i had a similar problem with ice building up on the back vent. it turned out to be the fan motor was not turning. i unplugged my refrigerator and used a hair blower to melt the ice. don't hold the hair blower to close to the vent so you will not damage the plastic vent.
Jan 27, 2014 | Samsung Refrigerators
My freezer to my Kenmore refrigerator has ice buildup in the back. Model# 106.72152111 I've been trying to figure out how to take off the back panel, and think I could probably defrost it from there. Only...
You will need to replace the defrost thermostat located on the freezer coils. To remove the rear panel, remove the ice maker if it has one, the there should be two screws that hold the back panel on. Remove them, tilt the top forward and lift out. You may not see them due to the ice buildup. Here is that part to order.
Sep 01, 2013 | Kenmore Refrigerators
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
MagicChef Beverage/Wine Cooler keeps getting ice build-up on inside back panel
Ice build up wil accor if the evaporater blower goes out and does not crculate the air. If you have the model number off the tag I can be of more assistance, with the mobel number I can break the unit componants down in a diagram
Oct 07, 2012 | Refrigerators
My freezer seems to be still working but my refridge isn't getting cold?
It sounds like you have an ice block. Depending on the type of fridge. There is a panel on the back wall of the freezer. Freezer on top models you have to remove ice maker . 3 screws in ice maker holding it in place 2 on top and 1 under. Two screws on back panel and 2 on bottom plate. See if there is an ice block when you remove panel. Coils should be frosted not iced up. If iced up than you will need parts. Defrost thermostat, heater, defrost timer are the ones that can cause and ice block. I would call a appliance repair tech for a definite part problem. Most will tell you the part as part of diagnostics. If you need further assistance you can write me back. Side by side models the panel is at the bottom behind the drawer. You will have to remove usually 3 racks above that to access the whole panel.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
The freezer drainage
you have a clogged defrost drain, remove the bottom basket, and freezer shelves to expose the screws for the back panel remove back panel,carefully chip away ice, and or use boiling water to melt the ice from the drain hose, check complete drainage by removing back panel behind frige at bottom and inspect that the water is draining completely into defrost pan. reoplace all parts.
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
