Question about Dryers
SOUTHWIND II, CEILING FAN,model 523763
Remote control not working
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
SOURCE: How to reverse ceiling fan for cold weather
Thank you for your response. After I posted ? a button was discovered. Problem solved! I did add this to my ? box yesterday.
Posted on Jan 18, 2009
jmgldsmth
  • 1889 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
The glass cover for my southwind v 52 ceiling fan is brocken. I need replacement. Can you help?
if you call the # below they said that you can order the glass you need. if you have it, they would like the upc code #. follow the instructions on the recording to get to the right place.
8 a.m. - 6 p.m., EST, Monday-Friday
1-877-527-0313
HAMPTONBAY.COM
Jan 12, 2015 | Dryers
I need to replace the receiver on a Hampton Bay Windward II Ceiling Fan. How do you take the fan apart to get at it?
028,085,091,042 are the codes to check. If you wish to get more, check these links. It has setup code list to many popular brand remote controls to various devices. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Universal Remote Control Hampton Bay...
My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward. I've tried everything I can think of to get the transmitter and...
If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
I hope this helps and good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceiling fan has no remote, does not work with switch
Home Depot/Lowe's etc have a remote kit specific to ceiling fans. your universal remote may not be compatible with your specific type of remote sensor that is up in the base of your ceiling fan. Check a user's manual to see the specifications of your specific Model # of fan to see what requirements they set for it. You would probably be better off just getting a new kit for an average $12 to get it working again.
Wish you luck.
Mar 10, 2011 | Universal Remote Control Hampton Bay...
Fan goes in reverse instead of pushing air down it goes counter clockwise. How do i reverse it?
1.) this model uses a remote control controller to operate its functions
2.) the reversing is done via that remote.
3.) the link is wireless
4.) do you have the remote?
Apr 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Hunter ceiling fan with remote will not reverse.
I was puzzled too... here's my fix... the remote has six buttons, the very small one at the top is the reversing button. Remote is part # 85095. It's a Westside II fan, bought at Costco.
Jun 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Jan 17, 2009 | Universal Remote Control Hampton Bay...
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
120 people viewed this question
Top Dryers Experts
