Question about AOC International TFT20W90PS 20 Lcd Monitor P/N: TFT20W90PS - Aoc Inte
Aoc input not supported
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
I connected my AOC moniter to TV tuner card.I can watch all the TV channels now but a box in the middle of screen displayed as input not supported. Please suggest me???
not certain what that means but check the broadcast protocols that are options of the card's menus and the protocols the monitor can use.
Also check the maximum resolution of the monitor, the refresh rates it can support, the modes too and check that the settings on the cards software are not exceeding them, it may be that the resolution or refresh rates are beyond the monitor's capability to display
Jul 02, 2015 | AOC Televison & Video
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
I am getting a INPUT NOT SUPPORT message for my 917sw AOC lcd monitor. It does work on safe mode I am using windows vista, but when I come back to normal mode, I see the same message again... HELP!!!
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps, Sherwin
Dec 21, 2009 | AOC 917Sw 19" LCD Monitor
Input not supported
screen resolution probably the problem if you have another moniter like a crt(which can support higher resolution) change it to the lowest level resoultion and then put in you lcd moniter and see if it works and if it does change the resolution to a comfortable level for you
May 22, 2009 | AOC A15X221 15 in. LCD Television
Aoc monitor set up
re install the drivers for garphic card or video card of your computer
thankyou for using fixya and dont forget to rate the solution
have a nice day
Feb 19, 2009 | Computers & Internet
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
AOC International TFT20W90PS 20 Lcd Monitor P/N: TFT20W90PS - Aoc Inte Logo
14 people viewed this question
Top AOC International Computers & Internet Experts
David Payne
David Payne
Are you an AOC International Computer and Internet Expert? Answer questions, earn points and help others
