Question about Bell Televison & Video
I own a Bell 9241 Sat Recvr, the remote that came with it was a 6.3 version and it stopped working. I was given a 6.4 but all it will do is turn on and off the tv. Can it be made to turn on the sat recvr and function normally?
  • 30 Answers
SOURCE: Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Posted on Jul 17, 2007
freetek
  • 5568 Answers
SOURCE: remote problem
Considering that none of the so-called 'universal' remotes really are, I would guess 'no' and this remote was designed for a specific system so your chances are even slimmer.
Before buying ANY 'universal' remote, check the remote mfr.'s website for a code list for the specific model you intend to buy and make sure that the devices you wish to control are included in that model. If you don't do this in advance, you will likely be disappointed.
The code lists are 'burned' into an IC in the remote and the only type that can accept new code sets are the 'learning' remotes and they do a lousy job; I own one of these and it will not accept input from either of my later TV set remotes.
Posted on May 17, 2009
SOURCE: my bell tv remote isn't working for sat but works
It would be best to call Bell technical support before going out and buying a new remote control, they can help you re-address the remote properly. 1888SKYDISH
Posted on Jun 03, 2010
BeckiB_DISH
  • 286 Answers
SOURCE: SAT button not working on remote--volume controls
Hello, there! My name is Becki Barned, with Dish Network customer service. You have probably already getten this resolved, but just in case it happens again, or you have questions, here is a link to our website, where you can take the steps to reprogram your remote, which is what is needed in this case. http://www.dishnetwork.com/SupportSection/remote-control I hope this helps in the future!!!
Posted on Dec 28, 2010
NickF DISH
  • 36 Answers
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Posted on Jan 03, 2011
Bell satellite receiver model 9241 pvr function doesn't work
Hello, if you receiver is on rental I suggest to get a replacement from Bell it's free if it's still on warranty, otherwise here is what you should try, open the battery panel there are screw there you must take off, then slowly using a butter knife go around the remote to unsnap the two peace open, after it's open you need a Q-tip and some alcohol, dip the tip into alcohol and drip the extra of the q-tip with your two finger you don't wish too much alcohol, clean the inside of each button, it should look like little black round rubber, make sure to change your q-tip if it turn too dirty, after you clean all those button, gently clean the surface of the electronic part, don't use too much alcohol and don't push to ******* the electronic, you just need to take off the dirt and grease that might have accumulate there with time, let it dry few 1 min, then close and it should work like a new one, let me know :)
Jul 02, 2016 | Bell Televison & Video
BELL RECEIVER MODEL 9241
Check this link to get more 3 digit codes.
Feb 24, 2013 | Televison & Video
Want to change remote address on the harmony remote for the bell 9241 reciever
Hello
What actually do you want. Your remote controls user manual? Quick start guide? Please clarify. Actually I didn't get you. OK.
Oct 21, 2011 | Logitech Harmony 670 Advanced Universal...
My new harmony 600 do not match with Bell 9241 hd remote do i have to bring back the harmony to store ?
Do not bring your remote back to the store. Check on logitech's site for help. If it does not help send the remote back to logitech.
Mar 05, 2011 | Logitech Harmony 600 Remote Control
My harmony 600 wont control my Bell 9241 PVR
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
Feb 12, 2011 | Logitech Harmony 600 Remote Control
I need a satellite Bell express Vue code (3100) I can't use the remote control Dish!!!!
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 23, 2010 | DISH Network IR Remote Control
The dishnetwork. Sighn just dances around the screen I push select and nothing happens
This sounds like this may be an issue with your tv 2, make sure your remote is in sat mode by pressingthe sat button. then select, if still nothing take your remote to the recvr and look on the back of the recvr to make sure the uhf ant. is standing straight up if not, straighten and try remote functions. if you stillg et no responce there could be other issues that are simple to fix depending on what kind of equipment you have. you can call 800-333-3474 for assistance or reply with recvr name or model #.
Nov 16, 2009 | DISH Network IR Remote Control
Was trying to mute the sound on tv when I accidentally hit another button. The t.v turned to snow and caption read to press SAT button. I pressed it and all I got was snow and no sat. reception. Can you...
If your recvr connect to tv via coax then put your tv on chan. 3 or 4 to reagin pic, if it a tv 2 location try cahn's 22 60 or 73 or run a auto program or auto tune.
Oct 10, 2009 | DISH Network IR Remote Control
Televison & Video Logo
18 people viewed this question
Top Bell Televison & Video Experts
ray gallant
Are you a Bell Televison and Video Expert? Answer questions, earn points and help others
