Question about Belkin (F5U237) 7-Port USB Hub
Belkin 7 port USB Hub
The front PS interface is jiggly after a very short period of use. I have shimmed over & over only to get frustrated. How do I open the hub without breaking it and fix this internal connection to stable again? Thanks
  • kaye1 Aug 29, 2007
    There are no screws. It was given to me as a gift and Belkin does have a lifetime warranty.
    I'll send it in with an RMA to Belkin.
    In central Texas, neither Circuit City, Best Buy or Fry's carries Belkin.
    I love this style & small footprint. The fact that it's a 'stackable' for several hubs is great. I have read one other post that had the same issue. Seems it is a design flaw!
    Scholar:
  • 53 Answers
I recommend you not to try to open it. The made it difficult to open for one reason and that is to prevent anyone to fix it so you have to buy another one but if you are experiencing problems of connectivity try this: remove the screws (if any) from the enclosure use a flat screw drive and insert it on the side of the casing's edge (right in the thin gap) apply little pressure and then push the screw driver down then up slightly, do this all around the case and with some patience you may get it open if you must use another flat screw driver to stick it on the part is already opened to keep it from closing back. Do this at your own risk there is no warranty you will be able to fix it once opened. I recommend you buy a D-Link hub they are reliable not to expensive, also easy to open. Good Luck!
Posted on Aug 28, 2007
  • Anonymous Aug 30, 2007
    It is good to hear that is got life time warranty that is great!!! anyway Good Luck
SOURCE:
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
F4U017 Belkin 7 port USB hub. No matter what i do, i cannot get this hub to work, i'm running windows 7 ultimate Home, i've updated and updated, it has got something to do with the...
Rimshot64, you did help someone out here. Two years later, even. And you succeeded where Microsoft "Help," per its tradition, failed. Thank you -- I got my scanner and printer, etc., back, and wasted only half a day uninstalling Microsoft updates (their suggestion).
Aug 02, 2011 | Belkin (F5U237) 7-Port USB Hub
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
I installed a 4 port hub to speed up my file tranfer to a flash drive. The files transfer but not any faster then using the front usb ports. It is normal?
Yes. While the speed from the USB device to the USB hub may be faster (USB 2.0 protocol, rather than the slower USB 1.1 protocol), your hub is still connected to a USB 1.1 port on your computer.
Aug 22, 2010 | Belkin ExpressBus (F5U021) 4-Port USB Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
Open Questions:
See all Belkin (F5U237) 7-Port USB Hub Questions
Belkin (F5U237) 7-Port USB Hub Logo
379 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
