Question about RCA Televison & Video
DVD not working
I have just acquired a Model: RLCVD2480A TV with DVD player. Whenever I put a DVD in the slot at the side of the TV, mirror-side facing me as instructed, nothing happens. I tried pushing the DVD in further, hoping that it would take it, but still nothing happened. I had to pull out the DVD with pliers. The unit is plugged in, and I pressed the source button and then selected DVD. Is there a cord I have forgotten to plug in? What else can I do?
hardrocko
  • 1476 Answers
SOURCE: atenna plug pulled out of tv, how do i get a signal now?
It has always amazed me how many "F" connectors get pulled out of tuners. I know because I've replaced hundreds, usually successfully, saving the cost of a new tuner. You need to unsolder the tuner from the board and remove the side cases. If the tuner board is not damaged beyond repair, (if it is you have to get creative), a new unit can be soldered in place. Put everything back together and you will be in buisness. New "F" connectors can be purchased from MCM Electronics at www.mcminone.com, part #215543 for $2.50. I always use a new connector as the old ones are usually trashed. Reliability is compromised if you don't use a new one. Technically you do not need the cable hookup since you have composite inputs. For my money I would just hookup a VCR (with a tuner) coming out of the VCR composite jacks into the TV composite jacks and use the tuner on the VCR leaving the TV in Aux, or whatever they call the composite inputs, and call it a day. It's you're choice but using a VCR tuner is faster, easier, cheaper and if you want to play a VHS tape you're already hooked up! If you are a traditionalist and want the TV 100% remember to be safe while working on it. Good luck whichever way you go.
Posted on Jun 23, 2006
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
  • 51 Answers
SOURCE: Time Warner Remote Codes
find your remote instuctions and it will say in them. dont follow the tv stuff.
Posted on Feb 11, 2009
  • 458 Answers
SOURCE: Tv wont switch on
This could be a problem with the power supply. Yes there is a fuse on the power supply & if you have a multi-meter & are competent with electrical safety, you could test it. However, if it has blown then almost certainly something else will have caused it. You might have a short circuit bridge rectifier or faulty chopper transistor. If the fuse is ok, then you will need to check voltages from the power supply to find out what feeds you have. There may be a start resistor open circuit for example. If most of the start up voltages are ok, then you need to look at the line output stage & check if this circuit is getting any voltage supply.
Posted on Jul 15, 2009
SOURCE: Will not come on
what is it
Posted on Aug 24, 2009
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
If i am on either AV2 or AV4 watching either sky or a DVD the TV will then change itself to channel "00" automatically after a few minutes. I am then unable to change back easily if i do then it...
A newly designed LCD TV has various capacity functionalities. For example, AV 2 or AV4 are connection capabilities with DVD or VCR recorder device peripherals. Once any devices are connected to the TV, an auto scan is required to acquire adjustment of what is common expection whenever powered on. USing the TV remote control, perform settings fucntionalities to acquire the auto scan to acquire connection functionalities. For example, refer to the TV user guide or manual on setting the TV channels. For TVs that are connected to subscriber providers cable tv or dishnetworks, contacting technical experts would readjust the TV signal receptables to display media. good luck
Jan 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
Won't load disc
Sounds like the lens is dirty and not reading disc take some rubbing alcohol and a q tip and clean lens the top side and bottom side (mirror side).
Nov 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Need codes for tv and dvd player/recorder.
This wasn't my problem! As I have explained before, I put the question on about a urc22B-12B control and FixYa somehow classed it as a Jensen.
Sep 03, 2009 | Jensen JR500 Remote Control
I have got sound but no picture on my toshiba dvd player,model number:sd-308kb,have tried various new scart leads,all to no avail,can you help,thanks,andy.
My Toshiba sd-310v required a S-video cable and
input programming at the TV to acquire a video signal. Hope this helps.
Aug 20, 2009 | Televison & Video
Help I got my DVD stuck in the DVD slot on my Ensignia TV with side DVD slot....
you may have to take the back of the tv off to get to the dvd player and get it loose...when u take the back off power the tv up in dvd mode and jiggle the tray for the dvd to see if it will come lose and release the dvd.
Jan 24, 2009 | Televison & Video
Just purchased a 32" Proscan Tv with DVD player
you need to switch the input from the remote to DVD and then insert the disc label facing to the back of the TV and the Mirror like side facing the fromt of the TV. You can also go to the Proscan website at http://www.oncorpus.com and download it from there.
Dec 31, 2008 | Proscan 32LA25Q 32 in. LCD TV
How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Dec 29, 2008 | Toshiba 26AV500U 26 in. LCD HDTV
Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
Apr 26, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
