Question about Logic CD700I In Dash CD/MP3 Receiver w/ USB Port & Front Aux Inp
Where can I find a wiring harness for a logic CD700i?
I have searched and searched for a wiring harness for this car stereo..hope you can help! Thank you.
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Wiring diagram for car stereo Can anyone help me find a wiring diagram for a clarion subaru car stereo? Model PF-2597A-B...thank you very much in advance!
Hello, I also have a 1999 outback and was searching for this information.(My speakers all of a sudden kicked out, and I can't figure out why) If you haven't already found it, here are two links I found helpful. This one has the pin diagram on the back of the radio http://ae64.com/WRX-pinout.htm This one has some troubleshooting tips. http://www.subaruoutback.org/forums/69-audio-video-security-navigation/10055-radio-but-no-sound-through-speakers.html
Apr 17, 2010 | Buck Subaru Outback 1999 Stereo/radio...
Aftermarket stereo wiring harness does not fit oem connectors. ordered stereo and harness together fom online car stereo.com. calledout a metra #70-1761. plugs will not fit either male plug. factory plugs...
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Jan 01, 2010 | 1995 Toyota Avalon
I want to install in my car a panasonic car stereo AM/FM/CD player CQ-EN9680TA, i dont know the wiring code of the terminal (power and speakers connections), can you help me pls? thank you
Hello marlomeneses,
Wiring color codes are different for different makes and models. Go here and select your vehicle for the color code: www.modifiedlife.com
The best way is to purchase a vehicle specific wiring harness that plugs directly into your car wiring. Splice the wires from the harness that came with your new Panasonic to the vehicle specific harness and plug them in.
Here's an example of such a harness made by Scosche. This one fits 2002 and newer Chrysler/Jeep vehicles. There's a harness for most all vehicles. Local car audio shops, Best Buy, and even WalMart sell such harnesses.
http://www.sonicelectronix.com/item_1669_Scosche+CR02B+-+CR02.html
Hope this helps.
Oct 06, 2009 | Panasonic Car Audio & Video
Need a stereo wiring diagram to reinstall factory stereo in my 93 toyota windom
You shouldn't need a wiring diagram, your factory plug should still be in behind the aftermarket stereo harness, unplug the aftermarket harness and your factory plug plugs directly into the factory harness.... hope this helps..
Sep 21, 2009 | Car Audio & Video
Rockford fosgate installation?
The best way to install a stereo deck is go get yourself a Scoshe wiring harness. This will allow you to wire the harness directly to the stereo, then plug directly in to the OEM wiring clip that is plugged into the factory stereo. It helps if and when you sell the truck and want to put the factory stereo back in. Plus you dont have to hack up wires. Hope it helps. You can get the wiring harness from any car stereo installation or customization shop.
Jul 27, 2009 | Rockford Fosgate RFX-9000 CD Player
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
Wiring diagram for 01 isuzu rodeo stereo
A few weeks ago I bought a new JVC stereo for my 2001 Isuzu Rodeo. I was advised that using a wiring harness would be the best option to install it. I spent an entire Saturday going from one store to the next (Autozone, Advance Auto Parts, Radio Shack, etc.) looking for the wiring harness specific to an Isuzu Rodeo but, to no avail. I searched several online sites looking for one and finally found it at http://www.beachaudio.com/ . The cost of the harness was under $10 and with express shipping I only paid about $20. Since I ordered it on a Wednesday night with 3 day express shipping, I assumed that I'd receive it the following Monday given any processing time and the weekend but, it was delivered to me just two days later. My husband installed my new stereo that Sunday using the harness that I purchased and it works great! Hope this information helps.
Nov 25, 2008 | 2001 Isuzu Rodeo
Aiwa CDC-X517M Car CD Receiver . . .
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Dave
Jun 20, 2008 | Aiwa CDC-X517M CD Player
Logic CD700I In Dash CD/MP3 Receiver w/ USB Port & Front Aux Inp Logo
21 people viewed this question
Top Logic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Logic Audio Player and Recorder Expert? Answer questions, earn points and help others
