Horizotal color line see display in laptop - Computers & Internet
  • 7,627 Answers
Symptoms of a bad Graphics Adapter due to overheating. You didn't post the Make, Model of Laptop? If it's a Graphics Adapter, the Laptop will have to have the motherboard replaced. You must make a decision, repair or replace. Usually the latter.
Posted on Jul 14, 2013
DIsplay problem
Sounds like the column/row matrix is dead. or the screen is cracked.
It's probably a repair job I'm afraid.
Jun 23, 2014 | Toshiba Satellite Computers & Internet
Display shows lines and color not displayed properly
A line vertically down the screen (usually bright green) is a failed column strobe. This can be caused by the connections at the top of the screen failing or the strobe chip starting to die.
Random colours can be caused by a cracked screen or a failed video card.
Best to take it to a repair shop for it to be assessed.
Jun 23, 2014 | Toshiba Satellite C850-BT2N11 Laptop
Horizotal lines on 42LGX
Check this site. It has screen shots to many problems and you can compare them to that of your TVs'. Surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 08, 2013 | Televison & Video
Prints with black lines horizotaly
just follow this step:
1.0 click start, then printer and faxes, right click your printer, properties, then click clean.Thanks!
Jun 25, 2010 | Kyocera FS-1030D Laser Printer
Vertical colored lines have appeared in my display.
turn on the system by pressing FN key and then the power but this should start up the onboard diagnostics let me know if the line are displayed during the diagnostic if it does the its the graphics. when it ask you if vertical or horizontal bars were displayed. select N so it can test the LCD panel if the lines are displayed there then it is your lcd panel.To make sureyour lcd panel is fine it will display solid colors.
Jan 20, 2010 | Dell Latitude D510 Notebook
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
Display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Dec 27, 2008 | Lenovo ThinkPad T61 Notebook
Two vertical lines on my compaq presario (M2000)
Try changing your screen desktop resolution to a different value. If you still have verticle lines, then try changing the color depth from 32bit to 24 or 16. If the problem remains your display adapter has completely failed. It has failed to compute column row addressing math.
Naturally, you would want to find and install the latest drivers for your display adapter with the hope that the failure is in the software driving the display adapter and not an onboard chip. If updating your drivers fails to resolve the issue you need to have service performed on your laptop. Most laptops have the display adapter soldered on the main circuit board and many shops are capable of replacing this chip set.
Yet, get a quote first as the cost might cause you to consider an upgrade into a laptop that has a display adapter that is Direct X 9c or Direct X 10 ready as that will run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
Worldvet
May 16, 2008 | Compaq Presario M2000 Notebook
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Wavy colors do not line up
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.eserviceinfo.com/
Oct 25, 2006 | Toshiba 56H80 56" Rear Projection...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
